Old 01-16-2015, 06:40 PM
Default Re: Liebherr LTM1800 scale 1/24
I had to come back for another look. Good stuff! Where did you get your shackles, or did you make them? Dan
Old 01-16-2015, 08:46 PM
kerst's Avatar
kerst kerst is offline
Thanks!
I bought the shackles from amazon, ha, ha! They are Steel D Shaped Shackles, 5/32" (4mm) thick, 5/16" (9mm) inside diameter.
Kerst
Old 07-01-2019, 09:31 PM
kerst's Avatar
I got inspired by this crane again and started to add the jib.
There is a fixed jib and a luffing jib available and they share many basic parts. So I started to make some of the parts that can be used for both. initially i will make the fixed jib and later the more complicated luffing jib.
Kerst
Old 07-16-2019, 10:00 AM
kerst's Avatar
Thank you for the kind remarks!
I made some good progress these past weeks.
Next is a 7 meter insert.
Kerst
Old 07-16-2019, 09:53 PM
I'm really digging the booms, and the jib boom connection in a pretty slick set up
Old 09-27-2019, 02:01 PM
kerst's Avatar
I decided to make the luffing jib as well and I am almost done. Only the pendants need to be made.
Kerst
Old 09-27-2019, 06:35 PM
Awesome work, as usual! That's a lot of fitting and soldering and machining and patience and all the other stuff it takes to make a complicated system like a crane.
Old 11-02-2019, 08:32 AM
kerst's Avatar
Finally I put it all together. Getting all the bits together took quite a bit of time and I had to make a few adjustments to the winch for the luffing jib.
yesterday was the day and it worked nicely. I am fairly pleased with the result and how easily the crane handled the luffer. It is testing time now and I am making a list of all the small adjustments that need to be made.
I am looking forward to the Cabin Fever Expo in January 2020. Then I can show it at full height! Ceilings are in the way at home.
Kerst
Old 11-02-2019, 08:39 AM
Bo Wallen's Avatar
Thumbs up Re: Liebherr LTM1800 scale 1/24
Looking good as usual Mr. Crane Guru. And it's ready for Cabin Fever also! Let's put it to work and have fun, got some beams in mind.........can't wait to see it up and running.
Old 11-03-2019, 12:28 AM
Looking forward to seeing the photos of it at full height and with Bo’S beams!
Old 11-03-2019, 02:54 PM
FabOne's Avatar
FabOne FabOne is offline
GREAT build! AWESOME workmanship!!
FabOne
NW Ohio
Old 11-03-2019, 04:54 PM
Wow that looks great!!!
I can't wait to see a video of it luffing and moving something
Old 11-30-2019, 10:50 PM
liddy102 liddy102 is offline
liddy102 is on a distinguished road
Nice work
Old 12-01-2019, 10:40 AM
Bo Wallen's Avatar
Lightbulb Re: Liebherr LTM1800 scale 1/24
Kerst, Just wondering how much weight you can lift safely, I'm making stuff to lift, don't wanna overcharge your lifting chart.
Old 12-01-2019, 04:40 PM
kerst's Avatar
Up to 20 lbs!
Old 12-03-2019, 08:51 AM
kerst's Avatar
I managed to get the paint job done during the Thanksgiving break and put it all together for testing. There is one back stop missing.
Here it is fitted with the fixed jib:
And here the luffing jib:
Here it is lifting a test load of 14 lbs:
And here with only 7 lbs:
Kerst
Old 12-03-2019, 10:18 AM
Bo Wallen's Avatar
Simply stunning! I've got some 4-8 and 12lbs. Ready to lift. You might need a spreader 4" by 20"
Old 12-04-2019, 10:26 AM
Wow, Please don't max it out on one of those picks.
Old 12-04-2019, 07:04 PM
Wow. Jaw droppingly awesome
Looks and performs amazing if you've got a 14lb load on the 1/24 crane!
Old 12-04-2019, 11:22 PM
Bo Wallen's Avatar
That's amazing 218750 LB Top Class
