Old 12-28-2010, 10:52 PM
Originally Posted by modelman View Post
Looks like you are making some progress steve-are you pleased with the way the model works with the boom section on? Is it strong?
I can't try the first section yet. If anything I'm going to just wire tie it under the temporary boom for looks and to keep fingers from touching it while at the show. But to answer your question Tom, It is very strong so far, much stronger than the temporary one that's just tacked together 1/8''x1/2'' flat bar.Also the safety lines add needed strength to keep it from buckling. I am almost finished milling angles and notching the tubes on the second section. After that is done I have to work on those dreaded splice plates again that took so long on the first section.
Old 12-31-2010, 05:35 PM
More pieces this week. I have 66 done but still need 39 more for this section of boom.
Drilling the chord ends 224 holes total 0-80 to tap.on these
A nightmare of angles
Old 12-31-2010, 08:20 PM
very cool!
Old 01-06-2011, 10:24 PM
I got the second section pretty much done this week on the 9W project.
Still need the 3rd section.
.040'' rivet detail
Fitting up the splice what a time consuming job this was trying to install all the 0-80 socket head screws
ready to solder
second splice
100' or 75'' scale boom
Old 01-06-2011, 11:18 PM
tracksntreadslou's Avatar
Wow Steve Looks awsome...So close to being done for the cabin fever and wish I could be there to see it in person..Im totaly impressed ...great work
Old 01-07-2011, 12:03 AM
You will have to come next year with all your forestry equipment . IH steve and I talked about having a stripping diorama starting with cutting trees then scrape the topsoil off and start removing overburden down to a scale coal bed to load out I was saying around here in the past, the coal co's just push all the trees into the pit and cover them up with a D11
Old 01-07-2011, 12:17 AM
that's just crazy!!
Old 01-07-2011, 11:09 AM
pugs pugs is offline
Looking great! hard to believe it has to get bigger yet.
Jeff
Old 01-07-2011, 12:28 PM
D8R D8R is offline
Fantastic work Steve, looking forward to see it finished. Is everything done inside, drums, brakes.....?
what´s the capacity on bucket?
Dan
Old 01-07-2011, 01:10 PM
Thumbs up Re: 1/16 Bucyrus-Monighan Walking Dragline
Steve great job looking forward to seeing it next week. Ed
Old 01-07-2011, 03:24 PM
All that brass!!!! What a monster!! Hope to see it next week!
Lynn
Thanks again everybody.
Dan
I need parking brakes for the load drum and walking gear. Now I know more about RC I can figure this out. I wasn't sure If I should use air but I guess a servo is the easiest. Not sure the exact capacity of the bucket.
Does anybody know of a source for lighting? I want some big spot lights on the boom. I was thinking of buying Mini Maglite reflectors and build my own using their Kypton bulbs. I found I site that has model boat spot lights. I may get one and see how it works.
Old 01-07-2011, 03:46 PM
D8R D8R is offline
On my model I will try using Plexi cut to size, drill a hole on rear and put a white LED.
The Plexi was bought as scrap at local dealer, LED´s are 5 for $4. Plexi comes in different sizes, sheets, rods, I use 1" sheet (part of) and cut with bandsaw.
My LED´s are 3,2v 20mA, 2 connected togheter can be runned on reciver battery.
The brass strip will be used as guards outside lamps (on CAT models).
Dan
Old 01-07-2011, 07:07 PM
Well Steve have you got it all packaged up for York next week? I will see you there. Ed
Old 01-07-2011, 11:47 PM
No, I'm starting the third section and hope to get it pretty much complete this weekend. I won't have the point sheave done so I'm going to just clamp a temporary one on.
Old 01-08-2011, 08:24 AM
Steve,
Talk to Willy (customrcmodels) about your lighting. He uses some 5mm LEDs on his tanks and trucks that you can not look at as they are so bright. They make the stock Tamiya headlights look like candles!
Looks like I will not be able to make the York, PA show next week Was able to get new computer and software for my CNC Sherline mill at a very good price so all of my available funds went there instead. Hope to see your dragline next year if all goes well.
Lynn
Old 01-08-2011, 12:13 PM
Originally Posted by tc1cat View Post
Steve,
Lynn
I haven't decided if I want LED's yet. I sort a like the older incandescent bubs. giving the vintage of this machine. I think you can get LED's in a off white witch may look ok. It would be nice if I could find some fixture that are already made.
Sorry you can't make it. Let's see some pictures of your new mill set up.
Old 01-11-2011, 08:49 PM
Steve-this looks really great! Your patience will be rewarded!!
Old 01-11-2011, 09:56 PM
Thanks Tom, I am busy trying to get the 3rd section pretty much done this evening but got cut short from running out of oxygen on my torch. I have all the pieces made and about 3/4 of it is soldered together. I haven't started on the point yet but I'll still be putting a block of wood up there for the sheave temporally so we can run it this weekend.
Old 01-11-2011, 10:55 PM
td9clyde td9clyde is offline
Dozer Builder
nice work i like all the detail jusy can't put it into words lol one day i will see your drag line model in person
