Old 05-27-2013, 05:08 PM
mpe's Avatar
mpe mpe is offline
mpe is on a distinguished road
Default Re: MPE – 24M Motor Grader Build
While I am waiting for the neck to come back form the machine shop I thought that I would post some pictures of a few of the parts that will get bolted to it.
Here are the support gussets and lower neck plate that helps support the front axle assembly and ties everything together.
Old 05-27-2013, 05:10 PM
mpe's Avatar
mpe mpe is offline
Here are the gussets bolted in place with 4 M2 x 4 mm SHCS for each gusset.
Old 05-27-2013, 05:12 PM
mpe's Avatar
mpe mpe is offline
This is what the bearing assembly that attaches the neck to the rear frame looks like before assemblied.
Old 05-27-2013, 05:23 PM
mpe's Avatar
mpe mpe is offline
This pictures shows the bearings and connector pin as it sits in the rear frame. The neck will get sandwiched inbetween the bearings plates and bolted in place with 12 M2 x 12mm shcs that clamp the bearing assembly and 3 M2 x 6mm shcs that bolt the flange part of the bearing plate to the neck. The connector pin is held in place by 8 M2 x 8 shcs.
Once the neck is attached to the rear frame it will be very hard to see these features.
Old 08-02-2013, 02:37 AM
mpe's Avatar
mpe mpe is offline
Old 08-02-2013, 02:38 AM
mpe's Avatar
mpe mpe is offline
Old 08-02-2013, 02:40 AM
mpe's Avatar
mpe mpe is offline
Old 08-03-2013, 08:19 AM
D8R D8R is offline
Originally Posted by mpe View Post
Looking very good (as usual), like those milled in mounting plates. See that there's other project's going on too, a drill that will be a donnor of it's motor and gearbox
Dan
Old 08-04-2013, 06:43 PM
mpe's Avatar
mpe mpe is offline
Dan
Thanks Dan.
I am not ready to give up my Dewalt drill for parts... she has been a good drill for me over the years when I was in the contracting business, although I am sure she would wear the 24M proud if it came to that.
Here is a glimpse of my project wall - all are in various stages of design and build. The D11R is most recent with about four years on the design. I am planing to start cutting metal in the near future on that one.
Old 08-02-2013, 02:41 AM
mpe's Avatar
mpe mpe is offline
Old 08-02-2013, 02:42 AM
mpe's Avatar
mpe mpe is offline
Old 08-02-2013, 02:43 AM
mpe's Avatar
mpe mpe is offline
Old 08-02-2013, 02:44 AM
mpe's Avatar
mpe mpe is offline
Old 08-02-2013, 02:46 AM
mpe's Avatar
mpe mpe is offline
Old 08-02-2013, 02:47 AM
mpe's Avatar
mpe mpe is offline
That's all for now...
Old 08-02-2013, 04:27 AM
max52 max52 is offline
max52 is on a distinguished road
congratulations nice work
Old 08-02-2013, 02:57 PM
really enjoy seeing the progress on your machine--model?
Old 08-02-2013, 03:06 PM
Really nice updates, MPE. I love all the little details. Making separate parts that bolt up like the full sized machine, is the most realistic way to go. The neck looks fantastic. Looking forward to more updates as they come.
Old 08-04-2013, 06:30 PM
mpe's Avatar
mpe mpe is offline
Little insight on the neck... I had place the order to the machine shop back in late January. The part was remachined 3 times before it was made correctly because of machining issues. 6 months later I had the part at my door. I had to do some slight machining on various features to get the correct fit that I was looking for but all in all as complicated as the neck was to machine - I am very happy with the final results and the job they did on it!
Old 08-03-2013, 08:29 AM
Very nice work you have a lot of Cad time on this. Ed
