Old 11-04-2016, 11:23 AM
Default Re: dresser TD40B dozer
They were there earlier. Probably a Photobucket error or something.
Old 11-04-2016, 08:21 PM
whew I thought it was my dinosaur of a puter . They where there last night .
I cant see any on the forum right now
Old 11-04-2016, 08:44 PM
I was trying to look up pictures of a previous build I had done and couldn't see any. Thinking something is broken.lol
Old 11-04-2016, 09:27 PM
tracksntreadslou's Avatar
It is coming together very nicely steve.Nice work .Looks chunky too on that workbench ..Looks as though PB is down ..i am getting the same thing as you ..hope they can save everything we already uploaded ..that would be a b****h if that was lost ..with all the bloody ads it is getting to be really painful to load and post pics
Old 11-04-2016, 10:29 PM
I think the ads on PB is killing me on this old (new to me ) puter . I can't update safari on it anymore . It's getting close to the 990's weight I started drawing up the hood and finalizing the cab . I've been playing with the 3D side of cad again and drew up the interior . I know, me with an interior in a model.
Old 11-12-2016, 10:05 PM
The VMC is tied up so ....they're supposed to be ball and socket but spherical bearings work just fine .
Pins and retainers for the blade components
pitch adjustment
blade done
Old 11-13-2016, 03:10 AM
Nice metal work, love the tracks!
Old 11-16-2016, 09:26 PM
Thanks ,Azonic
Tackleing the planetaries . I robbed the planetaries from my scraper since I'll be redoing the drive train in them .
Just the coupling from main shaft into the planetary .
Old 11-16-2016, 10:25 PM
How sweet it is when you have all the right tooling & the knowledge to use it to make whatever you want (I have no idea what I am talking about, I just assume it'd be sweet )... looking real good Steve
What's it weight getting to?
Old 11-17-2016, 10:26 AM
I agree steve-your machine work is perfect looking to me. The track (rails?)
look just like a real machine. The details are outstanding. This is probably the most realistic model of a dozer I have seen on this forum. Great work!!
Old 11-17-2016, 09:21 PM
https://youtu.be/QFDEZdykvig
Test run drill batts are ready for replacement fully charged they don't last long on my drill either
Joe this much of it is 60 lbs . So far with everything I have made to date , it at 80 lbs .
Thanks much Tom .
Old 11-19-2016, 03:14 PM
Great job! Nice transmission and final drives!
regards,
Frank
Old 11-19-2016, 06:25 PM
Thank you Frank
Tanks and trans filter house done and other side box. bolt head in oil tank werks out for a simulated sight glass.
Holy crap, Stevie gona have an interior !!
Old 11-22-2016, 10:26 AM
thebigo thebigo is offline
Just beautiful, a dream coming true for you Steve. To scratch build something like this is truly amazing. Like Joe, was just wondering what your weight currently is and what is the approximate total weight when finished? I have the RC4WD Dozer and it is just around 50 lbs, and ripping very hard clay is a challenge, which I like, but yours with all that steel should really dig, if you do add the ripper?
David
Old 11-27-2016, 09:13 PM
Steve-If I remember correctly you put one from each motor lead to the motor case. Been a while since I did this so you may want to check with someone else but I am pretty sure this is how I did it. Worked good, no radio glitches.
Old 11-27-2016, 10:05 PM
FabOne's Avatar
FabOne FabOne is offline
YES, I believe you're right.
-Terry
FabOne
NW Ohio
Old 11-28-2016, 06:56 AM
The Capacitors are to keep motors from sending emf noise out. If just 2 caps, they go from each lead to the motor can. 3 is better, with the other spanning both leads. Shorter legs are better so they can't act like antenna.
http://www.rccrawler.com/forum/elect...apacitors.html
Old 11-28-2016, 08:19 AM
Guys these are resisters not capacitors . I'll have to contact dimension eng to see why they put the resisters in with no diagram as to placement .
Old 11-28-2016, 02:07 PM
http://www.robotshop.com/media/files...-datasheet.pdf
Page 9 and 14 where it's talking about voltage clamps and braking?
Old 11-29-2016, 08:47 AM
thanks frizzen, I downloaded it a while back . Brain is proper now and I read threw the publication again . It turns out they're not needed in this application . I bought this 1 from robot shop and not Dimension, it turns out they add stuff to the package for same price as from dimension .
