Old 07-01-2018, 07:59 AM
kerst's Avatar
kerst kerst is offline
Wow!
Kerst
Old 07-01-2018, 11:11 AM
Hi DB it looks like you have gotten the mill figured out by the looks of your loader. Ed
Old 07-01-2018, 12:21 PM
Absolutely incredible work! Thanks for the update photos.
Is that a certi-flat welding table? Been thinking of getting one. How difficult was it to assemble? Stay as flat as they claim?
Old 07-01-2018, 02:35 PM
Thanks guys!! Yes it’s a certi-flat table. All laser cut pieces and very little draus to clean up. Assembly is very simple and straightforward. A couple taps with mallet and clamp together then weld the tabs/slots. Pretty clever idea for getting a pretty flat surface. I don’t have anything long enough or accurate enough to inspect the 4’ length of table to see how flat it is. 4’ Carpenters level is closest thing for me and table is probably more flat than level. I also got cheep bar clamps , removed end and welded a 3/4” bolt to bar. The stronghand tools are just nuts in price and cheep bar clamps are fine for what I use to clamp stuff down for welding. Moreso just clamping to weld and not trying to clamp down a warped or bent part. But yes I like it very much and am happy with the table. Kind of wish I got a bigger one .
Old 07-01-2018, 04:04 PM
These are the clamps I made.
Handrail parts
Fender mounting braces.
Wire distribution block hidden in rear bumper
Rear bumpers for articulation of rear axle, and steering hydraulics mount
Hydraulic tank. Plenty of oil, and this time I made a bottom drain.
Old 07-02-2018, 09:14 AM
Going along very well I see. I like the handrail mounting hardware.
I was looking at a acorn welding table a couple weeks ago. Would have taken it with me but a little too heavy for my box trailer. The table measures: 5' x 6' and weighs 3850# Taking a bigger trailer next trip.
You planning on coming down to Brownsville in August?
Old 07-02-2018, 07:15 PM
Like your clamps, great idea. I agree with you that the cost of the commercial "welding" clamps is insane. I usually buy the cheapest Harbor Freight clamps I can find for welding. Like you, just want to hold parts in alignment. Burn up a HF clamp or three it's no big loss. Also like the handrail ideal. How are you going to attach the stanchions to the pads?
Old 07-09-2018, 03:39 PM
thanks guys,
zabco, not sure what your referring to on the stanchions and pads? steps? if so industrial aluminum adhesive, (have to keep me in mind, I have no idea what some of the proper names of things are) my self earned degree in redneck engineering keeps me in the stupid simple relm two left feet and all thumbs sometimes
Old 07-09-2018, 07:29 PM
I was referring to the vertical components of your hand rails. Technically rails refer to the horizontal bars and stanchions are the vertical supports. But you answered my question anyway. Thanks and sorry for confusion.
Old 07-03-2018, 09:16 AM
Whats taking so long?? You'd think you're making each part by hand
Old 07-05-2018, 08:53 PM
Good work Cooper, great to see progress on this again.
Old 07-08-2018, 02:57 PM
You're making good progress on this
Old 07-14-2018, 07:20 PM
Here are the handrails using silver solder
Old 07-14-2018, 07:32 PM
And I have been wanting to make some sort of fixture for this type of work so I finally got around to it. Alum plate and small pieces with a groove in them for standoff’s. If laying flat on steel I risk the chance of soldering to steel plate. Laying on aluminum plate the alum sucks the heat pretty quick. So with the small standoff’s I can quickly heat and solder parts together. Also made clamping bars so I don’t have to worry about de-soldering or bumping existing joints/parts.
Now only thing I have to figure out is a more precise way to bend things. Maybe next project
Old 07-15-2018, 02:41 AM
Not only are you making a great model, but the tools are also one of a kind
Old 07-31-2018, 06:50 PM
Looks great cooper-I cannot imagine how many hours you have in that soldering fixture but it is necessary. When I was building sometimes I felt like I spent more time making special fixtures than working on the model. After this project it will probably sit and gather dust but hey that's what make things interesting. Nice work!!!!
Old 08-02-2018, 08:26 AM
I think the jig took about 30 min machine time. Just a couple to design. Well worth it for future projects.
Finally around to putting some clothes on this chunk of metal!! Was able to take partsup to a friends that has a big blasting cabinet with glass bead material. Really made shortsork of paint prepping. Several days of painting , many parts and several light coats to get good coverage.
Old 08-02-2018, 05:26 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
What is the hand rail, mild steel rod? Nice job!
Old 08-02-2018, 05:50 PM
yes mild steel, 1/8",,i think it was 12l14. easy to bend but not good for welding, so I soldered it together.
Old 08-20-2018, 10:17 PM
Mech_Eng's Avatar
Mech_Eng Mech_Eng is offline
Mech_Eng is on a distinguished road
Wow man!!! I have not been on in a while due to connectivity issues and the fact that I got super pi**ed off trying to make hydraulic cylinders a few months ago. My old lathe loves to cut a taper when I don't want it to....... Loader is turning out amazing! I feel guilty about my Tormach setting idle so i'm ready to get back in the saddle! I also may or may have not just sent a deposit to Fumotec......What tool are you using to get the "diamond" type pattern on the base of the cab? some type of engraving tool I guess? And what is the smallest endmill you have ran in the 1100? The detail work and lack of fasteners have made for a stunning model!
