Its be a while since i have checked out your build so Wow Nathan impressive ..This build is going to definatley be a one of...a show truck for sure ..Do you plan on painting yourself or farming that out ?..wish I had your peicients
![]() Quote:
Nathan |
Nathan if you want to anodize you could use a aluminum filler that Eastwood Companys has it is like fiberglass filer but is is aluminum and you use it like the fiberglass filler. I have used it on a few things and I like it. Ed
Okay, so it's a beautiful day outside and thought I would snap some pictures of the Kenworth in some natural sunlight. I spent some time working on the cab. I removed and sanded the original passenger side cast on air cleaner mount to make room for the new ones I machined. Then I drilled new holes and got the air cleaners and light brackets all mounted up. Here are some pictures.
![]() ![]() ![]() ![]() ![]() ![]() I'm really happy with the look that the look that the Kenworth has now. ![]()
Nathan |
Hi Ed, I've heard about Eastwood, but I never knew they had an aluminum filler. Might have to look into it, if I decide to have the cab anodized, but right now I'm leaning more toward a classy paint scheme. We'll see. Thanks for the tip.
Nathan |
Looking good. I like how it's coming together... Your attention to detail stands out!
I love the " look" or " stance" of it!
![]() ![]() Now get back to work! ![]() Mario |
Now that's got some attitude! Looking good
Hi my name is Aaron.... And i'm a truckaholic! |
You have done some amazing work on the 'ol girl. Aaron said it best, attitude
![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
As always you amaze me Nathan! Love the breathers with the interior light! Have you figured out what your gonna do for the headlights? I think it looks good in the raw form.
![]() Quote:
Thanks Aaron! Quote:
Thank you Jimmy! For the headlights, I have a couple ideas. I like the look of the All American Toys headlights, because they are true Kenworth replicas, but if I can't light them up, I'll have to go with a round single from another source. Maybe PMD or something. But for the All American Toys headlights, I was hoping I could take a ball nose end mill and hollow out the centers, than find a clear lens that would fit over the front. Run the wires for an LED out the bottom or something. We'll see. I don't think it will be very easy! The truck does look good in it's raw form, but I think I'll still paint it!
Nathan |
Nathan just grab your mill and mill the centers out and then put some plastic inserts in them and a light. Ed
Hey Nathan. Have you thought about pico sized led. Don't hog out the original lights just drill a hole to fit the pico led. These things are smaller than nano but seem very bright.
Size specs on this page. http://www.modeltrainsoftware.com/le...ined.html#pico http://www.modeltrainsoftware.com/smd-chip-leds.html Last edited by Supermario; 05-28-2014 at 04:35 PM. |
![]() Quote:
Not much in the way of BIG updates right now, but I've gone back and made a few little changes, to jazz things up a bit. My original stack mounts looked kind of boring, and I felt like they needed a little something more to dress them up, so I clamped them back in the mill and made some detail/relief cuts.
![]() In case you can't see the changes, here is one of the original stack mounts for comparison - ![]() Just a little something to go a long way to improving the looks. At least I think so. And if you're here checking out my thread, I thought I would throw in a few extra photos. I hadn't seen the Kenworth back together with the new visor, air cleaners, and stacks, so I just couldn't help myself. ![]() ![]() ![]() ![]() Enjoy!
Nathan |
Wow Nathan, long ways from the toy it was meant to be. Are your stacks and breathers the same diameter?
WOW Nathan the stacks and visor look sic.
![]() ![]() ![]() ![]() ![]() ![]() Big John
Thanks Craig. Yes, I think they are just about the same diameter. The stacks are 5/8" I.D. so the O.D. probably is 3/4", which is the same O.D. as my air cleaners. A little overkill........maybe.
Nathan |
It looks amazing Nathan!!!!!!!!!!!!!!!!!!!!!!!!, even the soldering on the stack joints are perfect!
![]() Quote:
Thanks wolfws6! Those solder joints were a lesson in patience. Solder a layer to build some low spots up, sand, check for more low spots, and repeat. It took some time to get it all smooth. Especially if I used too much heat and melted all of the solder to the point that it started to flow off the copper, making me more low spots!
Nathan |
