Old 12-02-2016, 06:44 AM
cosworth34677's Avatar
Default Re: Volvo A40F
wow!!
Old 03-05-2017, 04:29 PM
rc entreprenøren rc entreprenøren is offline
rc entreprenøren is on a distinguished road
Beatyfull work like allways on your model. One more master piece..
Old 03-15-2017, 12:53 PM
Snochaser's Avatar
This is my favorite of yours Ari if I had to pick. Love it. Great work as usual.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 03-15-2017, 03:54 PM
Bo Wallen's Avatar
Thumbs up Re: Volvo A40F
Ari. When Craftsmanship Shines Carry on Please.
Old 07-07-2017, 04:39 AM
Hi guys
I threw the electronics to the still unfinished A40 and made this test drive video.
https://www.youtube.com/watch?v=n0jCNxzAkcQ
Old 07-07-2017, 05:13 AM
Are you sure you just didn't shrink a 1:1 machine? It's just so scale looking.
Old 07-07-2017, 11:36 AM
I took the A40 and the 374 excavator outside and thought that I make a little loading and unloading video, but that did not go as planned. First I blew the oil return hose on the 374 (again) and a little bit later the planetary gear unit on the A40 tear down it self The bogie axles are in a quite side stress when doing tight turns on heavy load. I was doing a tight turn on a concrete surface and I noticed that the bogie wheels tends to "fall under", if you guys know what I mean. And soon after that one wheel with the hub came off. Apparently the planetary gear outer hub is only press fitted
No real damages done, but I'm a bit worried will the hub stay in place after I push it in, maybe I use some retaining compound.
Old 07-09-2017, 02:32 AM
What I did to fix the planetary gear problem was I tig welded few spots on the end of the drive shaft, so that the planetary gear hub can't move outwards.
I should have realized that when I was making the axles, but I didn't
Old 07-09-2017, 03:52 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi Ari
Great work as usual loved the new video on you tube as well
Regards
Mark
Over the Pond in the UK
my weather station
Old 07-10-2017, 07:09 PM
Understand, been using wax and that has lifted a couple times also. Went back to using double sided tape. It's a lot more clean up on table plate and part but haven't had any lifting .
Glad you brought up the turning forces, I would have never thought of sidewall forces under sharp turns. Really great work your doing!!
Old 12-07-2017, 10:54 AM
Ok. Beatyfull work Innedid.
Ari do you now.
I havet baught the dozer that Unix on this forum ha made.
I planting to powdercoat the parts. But the brass is souldered together. Parts are from 1 mm to 3mm souldered together. Do you think It Will go ok.?? At 190 degrees. For 20 minutes.
Old 12-09-2017, 01:07 AM
Ari do you now.
I think normal solder melting point is about the same, so you have a risk of melting joints.
Old 12-09-2017, 01:31 AM
I got the first 3D print of the bonnet from my buddy Steve. It turn out nicely, all though it is actually a test print to see how it fits to the rest of the machine.
It needs some small adjustments and after that I think it's going to be perfect
Old 12-09-2017, 04:28 AM
That's an AWESOME looking truck you're building!
Old 12-10-2017, 09:11 AM
Hofabooz's Avatar
Hi Hemi
Looking great the 3D print complements the machine perfectly nice work.
Looking for forwards to seeing this work progress..
Regards
Mark
my weather station
Old 12-10-2017, 02:56 PM
Looks real good Ari, the hood turned out nice and should finish off perfect!
Old 12-25-2017, 03:13 PM
Snochaser's Avatar
Can’t wait to see this completed Ari.
R.I.P. FGD
Never Forget- 343
Old 12-26-2017, 10:35 AM
How much time did it take to get that hood so smooth ?
Old 12-31-2017, 12:18 AM
Smile Re: Volvo A40F
This is the latest fixed size bonnet, it took 35 hours to print
Thank you for that Steve
Old 12-31-2017, 01:24 AM
D@M! That's a marathon print job there. It looks nice.
