Old 12-02-2015, 03:39 PM
Default Re: JBC limited NZ
I suppose it helps if I click on the publish button
Old 12-02-2015, 04:52 PM
Welcome back and glad to hear all is well after the fireworks and all.
The grinder definitely needs larger diameter sprockets but I don't think you'll need to up the speed. Can you also maybe change the bottom of the drive from a flat surface to something more knife edge or tapered a bit.
How much larger of sprockets are you thinking of using?
The hammer, But you need more speed there for sure..
Keep it up, looks great!
Old 12-02-2015, 05:23 PM
cheers Mario,
bigger sprockets are a must, but cant change the flat surface as that's the bottom of the gear box.
I think I will look at another 10mm in diameter (60mm), I will see what they have on their shelf and its gota be cheap.
and the hammer, yes there is a lot of changes needed.
cheers andy
Old 12-05-2015, 09:57 PM
had to rebuild the road I destroyed with the grinder, so took a little time and had a play while thinking about different ways to do the hammer.
https://youtu.be/J8YzG0Wbsvo
cheers andy
Old 12-19-2015, 11:13 PM
way too hot today to do any wife jobs,, so I dug a hole.
https://youtu.be/Is4m88L9sOU
cheers andy
Old 09-01-2016, 09:08 PM
it is a bruder , but not converted.
Old 10-05-2016, 03:14 PM
It's kinda sad to see this thread not updated regularly anymore, you have a lot of innovative ideas built with basic tools & good ol' fashion know how... hope to see you back 'er someday soon Andy, long overdue to see that tracked crusher in action.
Old 10-05-2016, 04:11 PM
hi Joe,
yes way too long but with starting my new business running a small excavator and truck theres just not enough time in the day.
thinking really hard about employing someone to help me out so I can get some more family time and of course play time.
The crusher can move under its own power but I need to redesign the conveyors as there is not enough clearance underneath .
Just need to find 10 hours and she will be finished.
hope fully things will slow down in winter and I can finish it.
Old 12-31-2017, 12:46 AM
Northern Farmer's Avatar
Thumbs up Re: JBC limited NZ
How’s it going Andy ? Haven’t seen you online in a while. Had any time to break out the rc’s ? Roadrunner looks and sounds great
Old 01-01-2018, 04:24 PM
Hi all and merry xmas and a happy new year.
Im still around and even charged some batteries for a bit of a play, but that never happened.
things are getting more organised so i have some spare time in the day.
because its summer here Ive been getting around as much as i can in the roadrunner and doing a few hot rod shows.
Skeeter , from memory the geared motor in the dump truck was around the 30rpm
range.
cheers andy
Old 01-01-2018, 04:28 PM
Thank-You, sir for the info.
I have GRU in mine for now, but IDK if the other builds are worth the $$, when one could simply place a gear motor on it, & have the SAME effect for far less!
Old 03-30-2018, 12:56 PM
So glad these photos weren't lost. Love the changes the 4200 went through to become the monster it is today.
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
