HA!! I bet you would get more interruptions in the full sized cab. People would want to see the controls and ask what you were doing in there!! Best bet might be to just wear ear plugs
![]() Lynn |
![]() Quote:
Ha, now... I don't know anybody that screws up when talking while operating? ![]() ![]()
Scott "No load is too Small" |
I haven't gotten too much into the Xbee cards yet (the wireless portion of the combo), but I do believe its like the 2.4ghz radios in that they have to be bonded together and are on a code to minimize interference.
I would highly suggest buying the arduino book listed above and taking time to read it, if it looks like something you can handle than start experimenting. The plus side of the Arduino board in the model is that it can be used like a little PLC to monitor and adjust things without you having to worry about it, like maybe limit switches or temp sensors to protect something.
Jeff Last edited by pugs; 03-19-2011 at 11:24 AM. |
Heck If I made it big enough and like the real ones there's usually a chair for the oiler and I could just draw the shades and sleep in there instead of my truck or tent.
Hey Steve, sound's like you have it covered for joystick's. Have you thought about having a camera inside the cab, and tv monitor outside. Let them see and no interuptus
![]() Pug's, thank's for the new link, hadn't heard of ps3 controler's being used yet ![]() Later, Neil#2 aka doodlebug. |
![]() Quote:
Well, I finally got the tip soldered together. Another milestone crossed. I counted 135pcs that were made for this section of boom excluding about 150 bolts. I hope to get on the safety rope mountings soon. There's also a set of deflection sheaves that help guide the hoist rope I talked about before that are made but I need to design the channels that they mount to.
End Plates ![]() Underside ![]() Inside of the rear pillow block ![]() Soldered ![]() Last of the lattice that needed installed ![]() Top section ![]() |
Beautiful!
Kerst |
I doubt it Brian. I don't have any little kids anymore. Now they want diesel pick up trucks.
Thanks, Kerst, I got tired of starring at all the parts so the last two evenings I just had to put it together. I need to learn how to make hand rail and the walkway up the left side now. How will the oilier get up there to grease the point. ![]() |
looks awsome i am still speechless of all the intricit details amaizing keep up the awsome work lol now looks like theres a euclid truck gonna be around to load and i can shove the load around
I built this thing and have it working now what do I do with it? |
Almost done?? Hand rails and walkways should be no problem for you. Just take your time
LYNN |
I'm never done with anything Lynn,
Your metal workis off the chart!!! Fantastic job on the boom. I wish i had the "metal" skills you guys. I'm still learning how to chuck-up my lathe
Giving up is not an option!!! Rob |
![]() Quote:
Just watch you don't chuck up your lathe too much. Maybe you need a bigger chucker. ![]() ![]() |
Got alittle done this weekend on the boom suspension ropes. Not much because I'm getting parts ready to go to the sand blaster for my antique road grader restoration.
I had to drill the "A" frame sheave shafts at a 3deg angle so they will track inline with the boom taper to the point. ![]() The shafts for the point sheaves ![]() I didn't have any 3/8'' hex stock handy,so I milled some round stock to suit. ![]() |
Very nice work as always steve!! Will the boom be painted?
Looks strong and heavy. I see more counter weight in your future.
I want to darken the brass with black patina hopefully Tom. That's going to take alot of elbow grease to clean everything so it'll take. I could glass bead it but it's too big for my cabinet. I'll have to waste the media into the air I guess. Another media I never tried is baking soda. I don't think it's all the destructive.
Yea, Scott, It is a little heavier we'll have to see how much weight to add. I have lots of room in the floor boards for lead shot. |
Steve. The workmanship on your boom is spectacular. You are a very patient man with all the details your building into it. I've used both soda and dry ice for cleaning up parts. I personally like the dry ice best, because there's no clean up after. They both work very well for detailed parts because their meant for that type of work.
Rob |
![]() Quote:
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
