![]() Quote:
No sir I don't have that info. As of this time, I've yet to start building either of those kits. I've heard others that have said the same thing about that seller. I guess I was one of the lucky one's that actually got the merchandise that was ordered. I'm sorry that this happened to you folks. Last edited by skeeter; 01-27-2018 at 10:46 PM. Reason: typos |
The HobbyCo bankruptcy has really messed EVERYTHING up! I went to the LHS today to try & acquire some square brass tubing, brass sheets, brass "C" Channels, as well as some more brass tubing. I need to acquire this stuff fir the Weyerhaeuser log truck build. I'm on a first name basis with the LHS owner. We talked fir several minute today about the bankruptcy, & how it's affecting the hobby supplies. He CAN;T order K+S brass stock no more. His supply chain was through a HobbiCo Company, Great Planes. Since K+S WON'T ship to Great Planes fir now, he'd have to place an order of at LEAST $1,000.oo to place an order directly with K+S. Even some parts fir RC trucks, & cars he's NOT able to order. Even Tacoma RC Raceways (The other LHS that has the indoor track, AND hosts the National Indoor Series of races) is having troubles finding parts. I guess that tomorrow, after work, I'll have to hit Evilbay, &/or Amazon to try & scrounge up enough materials that I can get started on this build. I tried Home Dumpster, & Lowes today, but they DON'T have brass stock that is as small as I am needing.
Hydraulic help needed. I plan to build another dump truck, but this one will have hydraulics to dump it.
![]() ![]() ![]() IF I must use a valve, I was thinking about this one. http://www.magomhrc.com/en/m3-valves...lve-m3-v2.html Problem is, it has 4 connection ports, but the hydraulic cylinder ONLY has 2 ports. ![]() |
You should look for a complete setup. In the end it’s not more expensive than getting individual parts. Magom is generally cheaper. Then you have Ledu and up to Premacon.
Emil G | MFZ Blocher Fendt 926 | RC4WD Volvo EC480 excavator | Carson LR 634 | Kenworth 6x6 hauler | Kenworth 6x6 dtrk My channel: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Construction site on Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Pictures on Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
No need for a valve Skeeter. Check out these kits.
http://www.rcbrmin.com/index.php?mai...roducts_id=643 http://www.rcbrmin.com/index.php?mai...roducts_id=649 |
![]() Quote:
Thanks guys fir the help. |
Didn’t catch that you already had bought a system. Do you know the brand? If it’s originally dedigned without a valve, it shoud work with any ESC that’s support fwd/rew. Brush/ brushless is then the only question.
It's a LESU HYDRAULIC KIT. I don't have pics of it. Semi Joe on EvilBay has a few pics of it. Here's one of his pics. Mine is exactly the same unit, sorry it's a SMALL picture.
If the cylinder has only one fitting then iTS
A forward to fill and reverse to empty setup Like my super dumper. If there are two fittings Then you need a valvebody to Chang flow directions |
I'll have to dig it out, & see how many connections it has. It was a long time ago I bought it. According to the Evilbay purchase history, I bought it in late 2016.
THANK-You to Rapheal & Jeffery for coming over to play RC truck & construction today. It was a blast, guys. Here's a few pics of the fun today.
SORRY the pics are so large. I accidently posted them NOT realizing that they were the LARGE sized pictures, rather then the MEDIUM sized.
Here's a some raw video footage from the fun we had today. I wanted to get more, but the camera battery died.
https://youtu.be/YKMru7RJTUI https://youtu.be/QRhmm-vZj6A https://youtu.be/BeX6Az7YXXo https://youtu.be/84fGvua227I https://youtu.be/Yd9sbuu5SuA https://youtu.be/tjrRytErle0 https://youtu.be/UaDhgttvSRw https://youtu.be/sytdz_-EoIE https://youtu.be/UXLcUZheanw https://youtu.be/LIm1vHB5Y28 https://youtu.be/LzmjBqSpIRY |
I got some goodies in the mail today! The 8 new cheapo ESC units, they arrived me. Also was the final brass stock I need to begin to build the log trucks headache rack. The nuts for the 2MM scale bolts that were acquired from RC4WD a while back came too. The bolts were direct from RC4WD, the nuts weren't available, so I ordered them from China. The local stores, Fastenall, & Tacoma Screw Products DIDN'T offer anything below 3mm.
![]() As soon as I get the logging truck as far along as I can go with it..............Still trying to source materials for the trailer build, then I'll be moving onto the New Bright Firetruck! Frizzy, I know that'll make you happy. |
I got the motor mounts back form the machine shop today for the 4200XL excavator this afternoon.
![]() ![]() I sent BOTH mounts, & one motor to the shop, so they knew exactly what I was wanting done. When they came back, they were BOTH on the motor, & secured with the set screws. ![]() ![]() ![]() ![]() Shortly after I got home with the motor mounts, my phone rang. ![]() ![]() ![]() ![]() Change in plans! ![]() ![]() ![]() ![]() ![]() |
Before I got the call that the motor mounts were done fir the 4200XL, I cut the cord!
![]() ![]() ![]() Then I had to open it up & take a peak inside ![]() I've got a couple ideas how/what to do for converting this...............but they'll have to wait for another month or two. I HAVEN'T forgotten about the Subaru WRX, just had other projects in the works. |
Sounds like you've been busy!
The excavators looking good with the better motors. Come on, now you're just trying to flatter me. I just like poking you to work on stuff and not be afraid to try doing weird things with it. Very few here build straight kits, or leave them stock for long, so it takes some extra creativity. It's a little more fun to see what was scrounged to look and work right than seeing an unboxing pic. "If it's stupid, but it works, it's not stupid" You set up a meet, and arranged a venue to let everybody go play and be entertaining, that's way more impressive than 'some guy on the internet said i should do a fire truck.' Yeah, free the WRC! Ya know, that's a really nice looking Impreza... I'd probably suggest doing the subaru before moving on to the ladder truck, since there's gonna a lot less going on in the scooby.
![]() Quote:
I'm excited for the meet to run the new motors in that machine. I HOPE the weather cooperates for us. Right now the ground here is frozen. I haven't even had a change to try out the new motors............YET. I CAN'T take ALL teh credit for organizing the events. All I did was host the first event at my place. The 3 of us that were there decided it'd be awesome to have a group of folks with similar interests get together monthly for RC Construction, & trucking fun! The Subaru is easy peezy, compared to the firetruck. It'll not much different then doing the New Bright tractor conversion. |
![]() ![]() As IF I needed to undertake MORE projects ![]() ![]() ![]() ![]() While I was at Fred Meyer the other day, I found these. Thinking outside the box, they may work well for trailer umbilical lines. At $o.99 each, if they DON'T work as I think they would, I have something to help repel those dam mosquitoes this summer ![]() ![]() Here's a lil progress on the D11 build. ![]() ![]() ![]() ![]() ![]() |
I made a lil progress on the Bruder D11 conversion today. The weather FINALLY wormed up enough that I was able to do some epoxy work. I mixed Epoxy, & bb's then placed them in the bags, & formed them to the cat.
![]() ![]() After the rear section cures, I'll trim the plastic away, as I did the front one. Now I've got to work on getting the electronics installed, & in working order. |
