Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Construction Equipment > Construction News
Construction News New kits & accessories offered in the world wide marketplace
Old 11-06-2015, 11:29 AM
Default Re: Magom HRC metal 1/14 track loader
Just let the moths out of your wallet and order one up.
Old 11-06-2015, 12:31 PM
Kausekaos Kausekaos is offline
Kausekaos is on a distinguished road
I really thing I'm going too honestly.
Not trolling anymore...
Old 11-17-2015, 04:35 PM
Just saw some new pics of this loader. Is it just me? Looking from this angle this thing has a very very low ground clearance is 15mm enough?
Old 11-17-2015, 07:50 PM
Great for ground rubber on a cement floor maybe. I understand why they probably did this but that's not much ground clearance. It will be constantly dragging it's belly that's for sure.
Old 11-17-2015, 08:21 PM
Never realized that low ground clearance. It looks good painted though. There's more pictures on their Facebook page.
Old 02-10-2016, 06:19 AM
trucker n's Avatar
Just purchased one will see what it's like when I get it
Old 02-10-2016, 07:45 AM
Mikem Mikem is offline
But doesn't the bucket move and level the dirt so the ground clearance wouldn't matter ? Just a question . I looked at there site Sunday and its out of stock I'll go look again
Old 02-10-2016, 07:54 AM
trucker n's Avatar
Yeah I saw out of stock I emailed them and got reply this morning that all was back in stock I also noticed they sell the Jung pump witch I wanted but they said it won't fit in this machine I also got the sound for it
Old 02-10-2016, 08:59 AM
Rakthi's Avatar
Rakthi Rakthi is offline
There are some pics of it being assembled on the Modell-Baustelle.de forum
Here is the link:
http://www.modell-baustelle.de/index...&threadID=8638
Old 02-10-2016, 09:09 AM
Rimrock Rimrock is offline
Magom got the Jung pump, but keep in mind that the motor/tank/ is Magom's own set-up (cheap) and will not perform as good as the same Jung pump delivered with Premacon or Fumotec set-up...This Jung pump is prepared for fare larger machines than this loader and would probably be needed to be tuned down to 10-20% of max performance, if at all manage to fit it in the machine
Old 02-10-2016, 09:49 AM
Depends on what Jung pump they're using, do you know?
Old 02-10-2016, 09:52 AM
Originally Posted by Kausekaos View Post
I emailed them to ask specs. Need to know how high the bucket lifts if it doesn't load the Dump truck its a waste for me lol.
That is a good question. I own a magom track loader,1/16 bruder conversion and it just makes it into the dump truck. Being that the metal version is 1/14 scale it should be high enough.
Old 02-10-2016, 10:27 AM
trucker n's Avatar
Joe the one they show for sale is 900
Old 02-10-2016, 02:39 PM
900 what?
The numbers I see stamped on the Jung pumps is 4001, which is 0,15ml/rev, 4002 is 0,30ml/rev, 4003 is 0,45ml/rev... they go higher volume yet, but I don't know the serial #'s or values.
Anything more than 4002 - 0,30ml/rev is over kill for these little models with small bores & short strokes, especially if direct drive then 0,15ml/min would be sufficient. I think 380 - 420ml/min is the correct flow rate for these small models.
Old 02-10-2016, 04:16 PM
It's the HR-7 / 4003. Magom does not use a reduction transmission, to keep cost down, installed a oversized motor in order to reduce the rpm. But I personally think it runs higher at full speed than the recommended 3-4000 max rpm for the pump. Too small tank (50-100 ml, vs Premacon 500 ml), no good cooling of the oil, which then more quickly gets hot and start foaming. Magom got much nice suff now, as the tracked loader, but they still got some way to go concerning their pumps, IMO.
Old 02-10-2016, 06:12 PM
So do you guys think this is a good beginner shovel . I like the price . Is there someone else's pump to use?
Old 02-10-2016, 09:08 PM
trucker n's Avatar
Smile Re: Magom HRC metal 1/14 track loader
I think is a good starter them maybe later upgrade to leimbach pump and valves
Old 02-11-2016, 02:01 AM
Northern Farmer's Avatar
I personally would go with the Carson LR634 but to each their own
Old 02-11-2016, 06:44 AM
4003 is 0,45ml/rev, way too much volume for these tiny bore short stroke cylinders!
I started with that pump in my Fumotec 490, it was like operating a pneumatic system, too fast - kinda springy movements. I put that pump in my JD850 & with it's much larger cyl bores, it's perfect speed, especially on the twin 18's lifting the boom.
I doubt Magom pays any attention to this forum, so my words are meaningless...
Old 02-11-2016, 07:58 AM
But will a liembach pump and valves fit ? Can the motor as it is be slowed down ?
