Old 11-21-2015, 12:18 PM
Default Re: Rcbrmin sound system help
mine is in the sleeper facing into the cab with no windows in the cab
Old 11-24-2015, 11:03 AM
blitzk's Avatar
blitzk blitzk is offline
blitzk is on a distinguished road
Hey guys, just one more question!! LOL. I just tried installing the second sound system into my "Pete" daycab but when all connected, ESC will not work. If I unhook the sound system, ESC works fine. Could it be the ESC is not powerful enough to run the sound system? Any help would be much appreciated. Thanks
Old 02-16-2017, 01:07 PM
roadranger's Avatar
White Line Fever
Sounds like a problem with the sound system hookup. Does the onboard LED light up?
The ESC signals are basically 'pass thru' going from RX thru the Sound Board into the ESC. Retrace all of your RX plugs and leads to make sure they're in the right slot. Sometimes it's tricky to get the ESC plugged into the Sound Board.
Make sure the separate SB power leads go to a 7.2V or higher battery. (I install an on/off switch in the power lead to shut off sound without unplugging battery)
And make sure the top programming plug is in the f1-f2 position.
Hope this helps...
WILDCAT T&C
Jim B.
Colorado Springs
Old 02-15-2017, 08:42 PM
ScottLay ScottLay is offline
ScottLay is on a distinguished road
Thanks for posting guys, helped alot with mine.
