Old 05-20-2016, 09:48 AM
Cat966c Cat966c is offline
Default Re: 966 update
Originally Posted by ihbuilder View Post
.032 is OK , but slow the wire feed down turn the shielding gas up ( if that is what your using. If flux core wire, clean your metal better.) a little more heat wouldn't hurt .
Alright, I will try that. Thanks!
Old 05-20-2016, 01:04 PM
As for the motor; could I use this motor/gearbox?
https://www.pololu.com/product/73
And if that one would be alright (enough torque, big enough motor, too many/little rpms, correct voltage, etc…) what kind of esc should I use, or could I just use any? And it says something on there about stalling causing overheating so that makes me wary.
Old 05-20-2016, 02:26 PM
Basically I am running 4 of these in my Bruder loader and compactor. https://www.pololu.com/product/1586 I buy them from eBay though because it is much cheaper. If you want more power you could go with the high output version with a slightly lower ratio. https://www.pololu.com/product/1577 The last ones are powerful enough to destroy their own gearboxes if locked up on 7.2v. I like the less powerful ones for this because they will stall without breakage and that also helps with steering.
Old 05-20-2016, 05:21 PM
Thanks!!! So a few questions: if I got the high output would it make it slower? And the last ones you mentioned are the 12v?? So I couldn't use them on a 11 mah battery? And if you're running 4 of the motors like you said, that means four esc's right? And what's an encoder? I saw that they have an option to come with one. Is that the thing that connects to the esc and/or receiver?
Old 05-20-2016, 05:40 PM
The ones I mentioned are 6v. You can get 12v options though. I think you mean 11.1V battery? 6v would scream on that but 12v would be fine. Just a bit slower than the rated speed at 12v. One $11 esc for all 4 motors like I explained in the other thread. You don't want an encoder....
Old 05-20-2016, 06:27 PM
Thanks (: Hmmmm, I didn't know as much as I thought I did
Um…does the voltage of the battery=the voltage of the motor ideally? Like if I have a 12v motor I need a 12v battery? And if I have more than one 12v motor, do I have to get a bigger battery? And how do 4 motors connect to one esc?
Sorry for all the annoying questions, I've watched many tutorials on the basics of motors and rc and stuff, but I didn't understand them.
Thanks guys (:
