Old 05-21-2016, 02:06 PM
Northern Farmer's Avatar
Default Re: RC4WD 4200XL models and nomenclature?
Originally Posted by TheBennyB View Post
Yea, I usually give a strike or 2 to vendors before getting on them but this is really getting out of hand. If it comes to it do u mind if I send them the pic of yours Farmer?
Sure Benny it ain't a problem use the picture, anything to help a member out. Have you contacted Tang about the issues your experiencing with one of their dealers ?
Eaglemach@foxmail.com
Old 05-23-2016, 01:54 AM
alaskantoy alaskantoy is offline
alaskantoy is on a distinguished road
I just received an email stating I received the "updated" valve hydro block. still having issues with slow movement, and the hydro lines loosening up and causing leaks and sucking in air.
Old 05-23-2016, 04:40 AM
Rimrock Rimrock is offline
Slow movement is likely due to air in the system. Too low oil level in the tank. I don't have a quick, good 'non messy' way of emptying the system for air, but maybe others have? Theoretically the air should come out by running all cylinders in and out enough times, having the tank filled up to proper level at first.
Adding thread locker to the nipples will not hurt. E.g Locktite 542
Old 05-23-2016, 08:37 AM
I just emailed Tang to see if there is a "new" 3 block version 1.5 or if RC4WD is being negligent on updating or misinforming customers on what they are selling.
Old 05-23-2016, 03:51 PM
Keep us updated. Curious to see what the deal is...
Old 05-25-2016, 08:20 AM
Ok, so heard back from Tang and he said the newest 1.5's do have an improved 3 valve block and not a 4 valve. He also said to make sure the flow isn't too high and stay at stock or a bit lower on the pump speed which we all know already. Seems a bit suspect until I see a listing to buy a "new" 3 valve block upgrade. If anyone has some pics of their 1.0 3 valve block could you post up please, would like to compare.
Old 05-25-2016, 09:53 PM
I'm totally confused with this one guys, and I'm sure others are too,,,,
When you say 3 valve block , how many actual servos are connected to the whole block? Three valves and one diverted valve? That's still the 4 valve block. Or are you actually saying the version you are referring to has ONLY three servos and does not have the diverted valve and is using pump with prv to divert flow back to tank?
Old 05-26-2016, 09:00 AM
You got it. 3 valve block=3 servo's an no diverting valve, just usual prv.
4 valve block=4 servo's. 3 for booms and bucket and 4th for diverting valve.
Old 05-25-2016, 11:42 AM
Wish they listed a clear description of the parts they updated over the years. Would make things easier to figure which version you have.
Old 05-25-2016, 12:15 PM
No kidding, though I'm sure the 12 year old that "tests" and boxes them up has no idea what they have in front of them, much less the distributor. I'm still not completely sold on this "new" 3 block. I've only heard good things about Tang so I'll take his word...for now!!
Old 05-25-2016, 02:47 PM
I've been following this and correct me if I'm wrong but isn't the new valve block just the same block ?, just three valves instead of 4?
Old 05-25-2016, 04:18 PM
Version 1.0 has a 3 valve block, supposedly 1.5 has a 4 valve block and the "newest" 1.5's have a improved 3 valve block. This is what I've been told by Tang and RC4WD. Not sure what the "improvements" are though.
Old 05-25-2016, 08:31 PM
With the new valve block they should update the 4200 to version 2.0. Would help clear things up for customers wondering if they have the correct parts for their version.
Old 07-01-2016, 03:20 AM
JDToumanian's Avatar
JDToumanian JDToumanian is offline
JDToumanian is on a distinguished road
I believe they took your advice on this... I just got my 4200XL version 2.0, I couldn't pass up the current sale price ($1792). It has the improved 3-valve block, sprung idlers, and different ESCs than I have seen before. No cooling fans either. The pump seems quieter than in YouTube videos I've seen, and contrary to what RC4WD's site still says, the tracks are cast aluminum, not carbon steel.
I'm quite pleased, it worked flawlessly right out of the box... No issues or complaints so far.
Jon
Old 07-01-2016, 12:12 PM
Jon
Interesting, mine has all that but still has a cooling fan on the brushless pump motor ESC.
Old 05-25-2016, 08:48 PM
Four valve block on the 1.5 version
"4-way reversing valve, the use of standard servo drive, a total of 4 road, one on the right side all the way to control the oil, under normal circumstances the oil flows back to the fuel tank directly, producing action after valve is closed, the hydraulic oil flow to the high pressure oil. The actual use only three road"
http://www.aliexpress.com/item/Rc-ca...a-5a821f4c27f8
http://store.rc4wd.com/Hydraulic-Val...15_p_1832.html
Old 05-26-2016, 10:20 AM
Got ya .
I'm pretty sure (not positive) but these are shipped from overseas (hk). Rc4wd doesn't see/touch them. At least mine came with overseas post.
Old 05-26-2016, 11:43 AM
Got ya .
Naw Benny's came from Cali and not Honk Kong, RC4WD must of have had it at their warehouse.
Old 05-26-2016, 02:29 PM
Nope, mine came from oversea's. Had to deal with DHL as more import tax was owed before delivery. I had to pay $100 out of pocket, luckily RC4WD reimbursed me via paypal. Just another wonderful experience of this excavator adventure provided by RC4WD. I believe your right, the only thing RC4WD has seen of these are the pics on their website.
Old 05-26-2016, 02:57 PM
My bad I must have miss read your post on the previous page. That's actually pretty good if RC4WD covered the duty fees on your excavator. No one ever payed any of the duty fees I ever had on any of my parcels lol That's usually how things go when buying outside of the country you have to pay import tax on it. Also had to pay DHL on delivery.
