Old 09-06-2016, 09:57 PM
Trucker_Jo's Avatar
Default Re: 3D Printed CAT 963K Track Loader w/Raspberry Pi Control
I'm excited to see some parts printed up, everything looks killer! Yet another build thread that threatens me to sell some toys to buy another one~ A printer of course.
Jarrett
Old 09-25-2016, 04:28 PM
RexRacer19's Avatar
RexRacer19 RexRacer19 is offline
RexRacer19 is on a distinguished road
Managed to get a few more parts printed and some hardware ordered. I now have over half the tracks printed (38 per side) and the hardware to link them together.
The front idlers are printed also. I chose to print them in halves to make it easier to get the concave dish to print well. 2mm dowel pins are used for alignment and then they are bonded together with acetone.
The drive sprockets were also printed. They bolted up to the motor hubs perfectly, and line up well with the tracks. There is a dummy planetary unit that will hide the screws and provide a more scale appearance.
I was also able to finalize my cylinder designs and get an order placed with Magom for the hydraulic system. I am looking forward to getting that stuff in so I can finalize my main chassis design.
-Jeff
Old 09-25-2016, 06:01 PM
Great job!
Old 09-26-2016, 03:52 PM
Manfred's Avatar
Manfred Manfred is offline
Manfred is on a distinguished road
It looks great.
Manfred
Old 10-20-2016, 06:18 PM
Rexracer 19,
Can you post a link to where you bought the 3/16 grooved Clevis pins please. Followed the link over on the D10b3d print build but they do not seem to have them any more. Appreciate any help locating the hardware and with you sharing the build.
Cheers
Trackerman.
Old 10-21-2016, 07:28 PM
RexRacer19's Avatar
No problem. I picked mine up from McMaster-Carr. "Grooved Clevis Pin w/Retaining Ring"
http://www.mcmaster.com/#clevis-pins/=14p669l
-Jeff
Old 10-22-2016, 06:49 PM
RexRacer19,
Thank you for the link for the Clevis pins. Printing the track segments, what side did you have facing down on the print bed? Really interesting build, keep it up and thanks for sharing.
Cheers
Trackerman.
Old 10-23-2016, 08:03 PM
RexRacer19's Avatar
No problem, Trackerman. It took me a fair amount of trial and error to find a way of printing the tracks that made me happy. I ended up designing some "ears" on the outside that provided a footing that stuck to the print bed and was able to be broken away cleanly after printing. There is also some support that goes under the pads and center section. The pic shows the print orientation on the left and what the support and ears look like on the right.
-Jeff
Old 10-23-2016, 08:47 PM
Rexracer 19,
Nice solution for supporting the printed part. Thank you.
Cheers
Trackerman
Old 10-25-2016, 08:59 AM
Machfab Machfab is offline
Machfab is on a distinguished road
Do you have the supports "necked down" where they meet the bottom of the track pad for easy removal? Are you cutting supports for removal or do they break away? How long is the cycle time for printing? Nice Work!!
Old 10-26-2016, 07:42 PM
RexRacer19's Avatar
The supports, other than the triangular pieces at the end of the track pads, are generated by my 3D Printing software. The way support structures typically work, is that the printer will skip a layer or two (user controlled) between the top of the support and the first layer of the structure that sits on top of them. That way the top of the support has a little time to cool, and the next layer is not "pressed" into the support layer below it because of the gap of the missing layer. This forms a weak bond which makes the support easier to break away. It all works pretty well, but the part does require at least a little bit of sanding/filing to clean up some scars at the interface.
I have been printing my tracks two at a time, and it takes one hour for the pair. I could print more at a time, but I was concerned that the extra time between layers would allow too much cooling and reduce the bond strength between layers. These parts will likely see the most stress over anything else on the loader, so I want them as strong as the printer can make them.
-Jeff
Old 10-27-2016, 06:33 PM
What is your material of choice for printing these parts? ABS?
Old 10-27-2016, 08:49 PM
RexRacer19's Avatar
I'm using ABS for most everything. It is easy to work with and can be strengthened and bonded with acetone. I am tempted to try some carbon fiber impregnated filament for the lift arms and front bucket pivot arm to see if they might be a little stronger.
-Jeff
Old 11-16-2016, 02:19 PM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi
What can I say great work this is the direction I wish to go with my 3D printer and CAD.
thanks for sharing
Regards
Mark
Over the Pond in the UK
my weather station
Old 03-20-2017, 09:30 PM
JDH429's Avatar
JDH429 JDH429 is offline
Looking good, any updates?
Jason
Old 04-07-2017, 12:34 PM
RexRacer19's Avatar
Thank you. This project had to be put on hold for a while. Hopefully I will be able to pick back up on it in a few months.
-Jeff
