Old 01-02-2017, 02:41 PM
Default Re: CrackerBox Test Chassis
Short update, got a little more done on the Cracker Box and got the dump body mounted on the trailer frame with the lift motor and mechanism working. Need parts to finish it up. Got to pick up some suspension parts and tires. Here's a shot of where the cabs at.
Old 01-02-2017, 03:27 PM
pontiacmann pontiacmann is offline
pontiacmann is on a distinguished road
Looks Great, very nice Work.
Old 01-02-2017, 05:12 PM
Mikem Mikem is offline
Looks good can't wait til it's done !
Old 01-03-2017, 07:30 AM
Thanks guys, I cant wait till its done either, to many projects I want to work on!
Old 01-03-2017, 06:44 PM
FabOne's Avatar
FabOne FabOne is offline
LOOK'IN GOOD Kent!
-Terry
FabOne
NW Ohio
Old 01-03-2017, 07:28 PM
Looks great Kent! Fantastic job on the cab. You working from scale drawings or photo's?
Old 01-04-2017, 07:36 AM
Originally Posted by FabOne View Post
LOOK'IN GOOD Kent!
-Terry
Thanks Terry!
Thanks Dennis,
Besides all of the photos on the internet I found a spec brochure that has profile drawings with the over all dimensions and expanded the drawings in my copier until I got the dimensions according to scale and went from there, you have to start with good drawings because they become very pixelated as you expand them. if I'm happy with it when I'm done I'll build a dedicated chassis to the proper wheel base and see if I can find nice spoke wheels and other period correct details for it.
Old 01-07-2017, 01:25 PM
Here's a reason why I built a dedicated test chassis. I bought one of these motor/planetary drives, 437RPM @ 12v. The volt range on the motor is 6-12v so I ran it off my 7.2V battery realizing it would be a little slower. It was actually to slow however smooth and controllable. So while taking a break from other projects on the bench I started playing with some stock cans I had laying around and found that bolting this Axial 27 turn up to the planetary gives me a good top speed and plenty of power. The true test will be going to a meet and load some construction equipment on it. Surprisingly I haven't found a less expensive alternatetive to replace the 3spd with. Buying new, the 12v planetary combo is $40 & the 27t Axial is $14, just need to figure out what to do with with the extra 12v motors down the road.
Old 03-29-2017, 08:06 PM
Kent,
I just picked up one of the servo city gear motors to try in the wrecker to save space over the 3 speed. Very nice looking unit, but I have 1 question. Did you pull the stock pinion off the 12v motor and reuse it as the picture appears or go to a different style pinion?
Old 03-29-2017, 09:39 PM
Kent lookin great. Nice details - headlight buckets and the relief cut top center look good.
Old 03-30-2017, 06:52 AM
I have 3 trucks with the 437 rpm planet motors I like them a lot . I like the speed and they still have enough power to pull my grandkids on my Flatdeck . What to with the trannys now
Old 03-30-2017, 07:37 AM
Kent,
Hi Dennis,
Yes I just slid the pinion off the servo city motor and pressed it on the 550 I used, don't care for that type of pinion but its worked running around in the house so I'll run it until it fails.
Hi Izzy, good to hear from you, thanks for the comment, just remember when you see it in person stand on the other side of the room LOL, its all hand cut and the hand isn't as steady as it used to be.
Mike, I'm in the same boat but i'll figure something to do with them. What battery are you running with your motors? I just run 7.2 nimh and they seemed a little slow since those are 12v motors, that's why I swapped the motors, made a big difference.
Old 03-30-2017, 03:26 PM
I'm running 7.2 batteries just like you haven't tried motor swap yet. But I can't play outside yet too much snow still .
Old 03-30-2017, 06:42 PM
We haven't had any snow to speek of just a lot of rain, been doing all my test runs in the basement. Let me know what you think when you get a chance to run.
Old 03-30-2017, 06:56 PM
Thanks for the information Kent.
I'm planning to swap out the 12v motor for a nice 27 turn 7.2 motor I have on hand. I tried 12v motors in a tank on 7.2 volts down at Danville back in the day. No power and way too slow.
Old 03-30-2017, 09:38 PM
I can't test in the basement too many trains in the way ! And this weekend we are getting 3 inches more snow !
Old 04-07-2017, 05:55 PM
Kent - busy, my free hand is for turds as well. Grab a straight edge or I like to pre score using my calipers. Kind of hard on the tool but they've held up.
Old 04-16-2017, 08:07 PM
Got some color on it, but the paints not done, going to bring it along later this week as a roller. Guess it's time to start planning a chassis.
Old 04-16-2017, 09:35 PM
Now I know where I saw this ! I've been watching it all along !
Old 04-17-2017, 07:32 AM
Ok now I get it, I couldn't figure out why you made that comment
