Old 12-28-2017, 02:30 PM
Smile Re: Rc4wd 870k wheel loader unboxing and review.
Originally Posted by bigpipespete View Post
Sure doesn't take you long to operate your machines in a realistic manner. Cant wait to see it outside.
Thanks Mike. It sure wasn't like this with the default settings from factory. I was barely able to control it.
JD customs has built a good machine, but the radio settings and some of the mechanical settings like the pressure relief valve were questionable. Once these were massaged, it was much more predictable and controllable. I prefer having all the drive sticks on the right side (similar to how a plane flys) and the bucket and arm left stick.
I will add to this that the pump motor, speed control and servos work much cooler now. You can touch the pump motor with your finger for as long as you want after running it for half an hour. Now I know why they took the rear fan out. Plus it makes room for the Lipo.
Surprisingly the electronics run very efficient. Only the drive esc and motor will get warm if you use it in 2nd gear which is expected and totally normal.
Originally Posted by Northern Farmer View Post
Great job Shawn! Thanks for demo. I’m sure it’s going to help out a lot of owners to see how you tuned your loader
Thanks Brandon. I'm pretty sure if I kept the default settings, parts would start to fail.
Old 12-30-2017, 04:13 PM
Default Re: Rc4wd 870k wheel loader unboxing and review.
Originally Posted by skeeter View Post
WOW! That thang has a LOT of reach! How tall is that paper bag?
Standard grocery bag is just over 17".
Max reach to the bucket pivot point according to rc4wd is 18"
I did some rough dimensions comparing to the dimensions of full size cat 980h (pretty much the same as liugong clg888) and the result is 870k is much closer to 1:12 scale. Not 1:14 as advertised.
Old 12-30-2017, 07:01 PM
Northern Farmer's Avatar
Thumbs up Re: Rc4wd 870k wheel loader unboxing and review.
I’m not surprised as when you see the 870K next to other loaders that are 1/14 it’s all together a bigger machine. Gotta love that extra reach though
Old 01-15-2018, 05:24 PM
I put her in the dirt. I get better operating on the 2nd video. Surprisingly the Lipo lasted approx 35min each and I stopped it at 11.5v Very efficient. Used 5800mah lipo.
1st time in dirt: https://youtu.be/I0XeHrY7c_s
2nd time in dirt: https://youtu.be/SaeX06onUxY
Old 01-15-2018, 06:48 PM
Awesome videos Shawn
Old 01-15-2018, 08:37 PM
Once again your video quality is awesome , are you going to get some decals made up for the 870K ?
Old 01-15-2018, 09:06 PM
Thanks all.
I'm debating on what model to make it. It already has CASE colors so maybe a 1221F?
But just recently i saw someone who made a whole new engine hood and converted to CAT 980. It looked great! Here is a link to the video: https://www.youtube.com/watch?v=EVfm...2V87JesLCevhOg
Old 01-16-2018, 08:33 AM
Thanks all.
I agree, the guy did an awesome job converting his loader
Old 01-18-2018, 08:00 PM
This is your opportunity to have the first Case loader out there.
Old 01-19-2018, 10:11 PM
lenny lenny is offline
lenny is on a distinguished road
The 1121G with the grey wheels is a slick looking ride and different then most. Thinking I'm going to make a new engine cover. Eliminate the gray crossover under the hood, fix the air cleaner and ext to the hood and gain much more Batt space.
Old 01-20-2018, 03:36 AM
jack van's Avatar
jack van jack van is offline
so i went and got 4 zippy5800 mah lipo battery seems they have different type of connectors than the 870 loader is there a set of adapters from bullet con to the connecters for the zippy batteries
Old 01-20-2018, 04:51 AM
Yes, search evilbay, they have several kinds/styles. Or you can take it to your LHS & have them solder on new ends fir you, or do them yourself
Old 01-20-2018, 08:58 PM
Just installed Beier USM-RC-2 sound/light card. I'm using default settings with a prerecorded liebherr L586.
Haven't fine tuned it yet. I have to reverse the back up beeper noise. The software has a learning curve.
https://youtu.be/c7EtgRxznL4
Old 01-20-2018, 10:46 PM
Can’t beat that sound unit! Has lots of potential. You must have seen these videos before
https://youtu.be/0IR4jyELMO0
https://m.youtube.com/watch?v=1OWF9nibiD0
Old 01-22-2018, 09:36 PM
The pump is so loud on the first video. I've seen the 2nd video before. Thanks!
So after messing with mine, I finally decided on this sound. It sounds throatier in person compared to the video.
https://youtu.be/k1f48dYiKKg
Old 01-25-2018, 11:33 PM
Adjusted the turbo noise. It was too loud before. Now it sounds better. https://youtu.be/SYTcsaYZOOQ
Old 01-27-2018, 11:02 PM
jack van's Avatar
so my 870 loader is a 50 lbs piece of crap rc4wd is crap
Old 01-27-2018, 11:03 PM
Details please, & thanks.
Old 01-27-2018, 11:50 PM
jack van's Avatar
problem is i do not think i can take that much of the machine apart and get it back together again lol i am sure it is the wire from hydro pump it is only thing not turning on and mortor for wheels do not move
Old 01-27-2018, 11:58 PM
PM sent
