Old 01-29-2019, 12:59 AM
DADSGARAGE's Avatar
Default Re: Euclid R-62 dump truck
Looking forward to watching this build!!! Interesting truck!!!
KP
Old 02-09-2019, 01:21 PM
kerst's Avatar
kerst kerst is offline
I made some good progress on the suspension. The front axle is ready, but the rears need more work. The springs are made from worn out hack saw blades. They are very flexible and only the teeth are hardened, so it is easy to cut them.
Kerst
Old 02-12-2019, 05:16 PM
bobmorey bobmorey is offline
bobmorey is on a distinguished road
Kerst
Really cool looking truck. Great progress so far. Curious it looks like the hubs are plastic? Is that for ease of machining or to save weight? Where do you find details and dimensions for a truck like this? Lastly will you use servo/actuator or hydraulic for dump box?
Looking forward to your progress.
Best regards,
Bob
Old 02-14-2019, 07:20 PM
kerst's Avatar
Originally Posted by bobmorey View Post
Kerst
Best regards,
Bob
Thanks!
I used plastic for the wheels, both because it is easy to machine and it is light.
I don't have a lot of info on the truck, but there are enough pictures on the internet.
I plan on using hydraulics the dump function. I will make the cylinders myself. That will be a nice challenge!
Kerst
Old 03-02-2019, 09:21 PM
kerst's Avatar
I made good progress with the cab and the hood. The difficulty is finding the right measurements, but I think I am close. It starts looking like a big mean truck!
Kerst
Old 03-04-2019, 09:23 AM
If you come to the watch fob show at Lakeside Sand and Gravel this year,
You could get some from Larry's 1:1 truck.
Old 03-04-2019, 03:39 PM
Old 03-04-2019, 06:22 PM
FabOne's Avatar
FabOne FabOne is offline
Look'in GOOD!
FabOne
NW Ohio
Old 03-04-2019, 09:44 PM
kerst's Avatar
Thanks!
A bit more progress:
Kerst
Old 03-05-2019, 01:56 AM
That's looking cool
Old 03-14-2019, 12:51 PM
I'm loving this build. It's looking great!
Old 04-07-2019, 05:13 PM
DADSGARAGE's Avatar
Looks great!! Keep up the nice work!!
Old 04-12-2019, 06:53 PM
kerst's Avatar
Small update on the Euc.
I didn’t have much time lately for a variety of reasons, including a bad cold that kept on coming back.
But I managed to get the drive shafts done. I installed 2 temporary gear motors and that gave me the opportunity to test the truck and worked out some problems in the drive axles.
Kerst
Old 04-13-2019, 09:31 PM
Kiffer Kiffer is offline
Kiffer is on a distinguished road
Really looking good can’t wait to see more
Old 04-14-2019, 12:14 AM
That dual drive setup is slick.
Old 04-15-2019, 09:06 PM
What is the plan for the operation of the dump box
Old 09-24-2019, 09:07 PM
kerst's Avatar
I did some work on the Euc. I installed a Mabuchi 555 12V DC Motor, which seems to have sufficient power for this truck. And I built a temporary reduction box, so that I can drive it around and get a sense of the speeds. later I will build the final gearbox.
I tested the Euc in the dirt and took some videos:
https://youtu.be/V9AssoKzzBI
https://youtu.be/zraLPbm_xeM
Kerst
Old 09-24-2019, 11:23 PM
Krewmember's Avatar
Wow, that looks really good! I look forward to seeing it finished.
-Shawn-
Old 09-26-2019, 09:08 AM
That truck looks GREAT!
Old 12-14-2019, 07:31 PM
kerst's Avatar
I tried a simple mechanism for the tipping. It is basically a geared motor with a small winch pulling a lever, which does the tipping. This is the first try and I managed to lift it with a 11 lbs load. Not bad. Now I can optimize the design and I am considering putting the motor in a different spot. the space behind the cab is perfect for the battery.
Here a video: https://youtu.be/CMy56WsefUk
Kerst
