Old 08-19-2021, 11:30 AM
TaltosVT TaltosVT is offline
TaltosVT is on a distinguished road
Default Re: Green Mountain Girl - Grand Hauler Build
I didn't forget about this thread, just been too busy to update. :-)
The next couple of sessions were dedicated to constructing the fifth wheel and starting on the cab. The fifth wheel was pretty straight-forward. For the cab, after starting to install it, I decided that the floor was too plain, so I added flocking, then painted it, to add a little texture. For the seats, I used styrene to fill in the backs.
Fifth wheel plate was painted to match the frame.
I had to try the cab on to see how it would look.
The standard hollow backs needed some filling.
To get the size of the seat backs, I slobbed on some wet paint and made in impression on styrene sheet. When the paint was dry, I cut inside the lines for an (almost) perfect fit.
With the seat back in place, a little filler in the gaps helped smooth things out.
Finally, cut the hood of the cab. This was done carefully with a craft knife, and took far longer than I expected it would.
-Elroy
Old 08-19-2021, 11:38 AM
Next up, some upgraded rear wheels. I really like the look of these.
Hub pieces:
Comparing the standard plastic wheels with the upgraded aluminum wheels:
Looks nice with matching rear and front wheels:
Before working on the cab more, I made an attempt at adding a 3D printed engine. I found the file on Thingiverse, and scaled it as best I could. It turned out a bit smaller than scale, but I moved ahead with it anyway.
Engine still on the printer:
Cummins engine, right side up:
Test placement:
Trying the engine with the cab in place. About half of the print was cut away to fit over the model's motor.
-Elroy
Old 08-19-2021, 11:42 AM
Painting and adding the seats and engine:
-Elroy
Old 08-19-2021, 04:09 PM
NRS91 NRS91 is offline
NRS91 is on a distinguished road
feel sorry for that little 5.9 powering that whole rig
but awesome build!
Nick
