Old 12-10-2011, 09:11 PM
Default Re: Pete 367 in brass
Great build Sir! I am also building a couple of brass trucks and when it came time to build the hood and roof I decided to build them from copper instead of brass. The main reason is due to how malleable it is over the brass It will form the corner with the use of a little heat. You can just build a wooden buck instead of foam so you can hammer and heat it over the wood..just another way to build...
Old 12-12-2011, 07:25 PM
Timmy Timmy is offline
Timmy is on a distinguished road
Crawler07, thank you. I've used woodenbucks many times in my day to day job as an automotive restorer. I may still go that route if I can find a small piece of hardwood. I shied away from copper only for the reasoning of possably polishing the brass as opposed to painting, but copper could be a neat contrast, I may just do that now
Old 12-12-2011, 10:09 PM
Timmy, what type of welder are you using on the bed?
Old 12-12-2011, 11:03 PM
I'm using a 115 volt mig with a 25/75 mix of argon to Co2
Old 12-15-2011, 08:54 PM
So I've decided since I have to build he roof again anyway, I might as well take crawler07's advise, and build a wooden buck. The buck I've made is a simple one, and I built it out of 1/2 inch balsa. I don't intend to hammer against the form, just use it as my guide. I've annealed my brass before starting so that I don't have to heat against the wood either, not a good idea with balsa, my wife would kill me if I set fire too it. Here's some shots of the basic wood form
It's a nice dock isn't it
Cut to general shape
Now this picture shows the height of the buck, the buck it self is 1.3cm tall (when I scale I use centimeters and millimeters, one cause I'm Canadian, and two it's easier then figuring out thousandths) this happens to be the exact scale height of the roof after it slips onto the cab, so as I shape the buck, I will have to keep this in mind
I'll post more pics as I go
Old 12-16-2011, 09:48 AM
I finished the final shaping and started building my new roof panel last night
It looks tall, but the dimensions are correct, and the roof will slide down slightly from here
The shape looks very good in the side profile
This is the beginning of the new skin
I may build the roof in 4 pieces just to ease the metal forming, it will cause more work finishing the solder joints and smoothing it, but sometimes the longer route is the easiest. And if all else fails, I can smooth the buck even farther and stain it, a nice wooden roof for this Pete lol
Hope you enjoy
Old 12-16-2011, 11:45 AM
civic83 civic83 is offline
this may be a stupid question, but how do you guys get such nice cuts in the brass sheet? I find if I use snips the edges arent very nice no matter how i cut it, you can see "pinching" and tooth marks from the jaws. is there different shears available that are better? the only sheet metal experience i have is from high school shop and we used a foot operated shear that made nice cuts but i dont have the room or budget for such a machine.
Old 12-16-2011, 12:11 PM
There's no such thing as a stupid question! I've posted a pic of the cutters I use
I'm using .010 brass so any good quality scissors from a sewing store are the best choice. I also use a pair of my old snips from work, they work good, but yes they do leave a knurled edge which you can fix with a fine file. The pair in the picture are snap-on, but a quality pair of Wiss snips from a hardware store work aswell. I also use flush cutters. You can get them from your Lhs. I use these in very tight corners, and you need to dolly the brass smooth after which can cause or will cause some stretching in your piece. Another thing to consider, especially if your cutting long pieces is that both the scissors and the snips will curl the brass as you cut. Scissors aren't as bad as snips, but it will happen. So to solve this I use my little brake. Insert your piece, line it up as if you were going to bend it, then simply score the brass with a hobby knife or utility knife, bend it, fold it back and it will brake with a nice clean edge.
I hope this helps, if there's anything else feel free to ask
Old 12-16-2011, 09:40 PM
Here's a quick update on where I am with my roof forming
Much more work to be done, but it's taking shape
Old 12-17-2011, 04:50 AM
Thanks for the info, I hadn't considered using the small brake I have to do cuts, I'll have to try it! Your build looks great by the way!
Old 12-17-2011, 09:07 AM
Thank you for the compliment! Knowledge is only good if you are able to share it! Il hopefully have some more pics up today of the finished roof assembly, fingers crossed.
Old 12-17-2011, 01:32 PM
Here's the update on the roof. It took approximately 6 pieces, but it looks pretty good
In this pic, I've just finished soldering hence the clips
And here it is beside the buck
It's going to take much time to file and smooth, but I'm hopeful the end result will be worth it
Old 12-17-2011, 10:02 PM
I either need a life, or I need to go back to work lol! Anyway, here's the rest of today's accomplishments
These are the four pieces that make up the cowl
They fit quite well
Three pieces become one
Here it's all fitted together and tacked together, just a couple of tweaks needed
I think it's pretty
Here's the finish solder
It took close to 2 hours to get it filed and smoothed this clean, and there's a touch more to do
Here it's fitted back to the cab, the fits quite good
Sitting on the frame with the roof in place. However, I realized one of my fears, the roof took on a twist from the heat. I should have added my inner structure before I finish soldered it, impatience wins everytime. In the end though it should be good.
Hope I'm doing a decent job of representing a Pete at this stage.
Old 12-18-2011, 09:33 AM
CustomClod CustomClod is offline
CustomClod is on a distinguished road
I think it looks great. Your well on your way to having a pete! Keep up the great work!
I run a single stack Mack with a dump body on the back!
Old 12-18-2011, 02:04 PM
SWAGGER's Avatar
SWAGGER SWAGGER is offline
That's some seriously good brass work there. I think you are doing a great job and I admire your patience and skill. Good on ya!
Old 12-18-2011, 02:30 PM
Brian in PA's Avatar
I'd rather be truckin'
Looks like a Pete so far!!
Old 12-18-2011, 05:22 PM
Great job! And if going back to work is going to slow you down on this project I say stay at home..I cant wait to see more!
Old 12-19-2011, 09:32 PM
Thank you everyone for the kind words. I was afraid it was looking generic.
So today I started on the hood. I have much more to do to the cab, but I want a small change of pace for a bit
This is the top panel, cut slightly larger then needed
Really it doesn't look much different other then a slight curve added
These are my curved extensions to reach down to the side panel, this also shows the break I use aswell
This makes the last pic make alittle more sense
The needed " I started to solder it" pic lmao
And here I've lined it up to the cab, it looks kind of silly yet, but in the end it should look just right.
Some of you may have noticed I've strayed from the 367 models hood design. I made a fiberglass hood for it, but I just didn't like the look, this hood design is based on a 389 model, but could I get some one to give me the overall height measurements front and rear of the hood. A standard kh hoods dimensions are fine. It would be extremely helpful, thanks in advance
Tim
Old 12-20-2011, 10:37 AM
I thought I'd add the picture of my original fiberglass hood, it's just the rough form, and I'll keep it around for a future project.
Does anyone think it looks dis-proportionate, I think it does
Old 12-20-2011, 08:10 PM
You make this look like a blast to do and you do it very well! I've got to get some brass and practice soldering. Do you sand your tacks and joints or use heat to smooth them out?
