Nathan my friend, what can I say?
This truck is absolutely beautiful, even un-finished. Your attention to detail, along with your fab skills, is amazing. I have still yet to figure out how you narrowed that axle tho. I'm only seeing one seam on it. Care to share?
Rick.--- I suffer from Wedicosis ------------- My other truck is a Komatsu To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Thanks Rick! I really appreciate that. Here are the details on the lift axle mods.
![]() What I did was mill two notches or 'steps' into the center section of the axle. I did not cut the axle in half, but rather milled a notch on one side, flipped the axle and milled a second notch. Where the notches met in the middle, the axle became two pieces. Once the halves are over lapped, the axle is effectively narrowed. ![]() I drilled some holes through the modified center section, and tapped the lower holes for some 3mm screws. When assembled, the two 'stepped halves' of the axle seat against each other, and the 3mm screws just keep the halves solid. ![]() ![]() Now what I didn't think about was how I would make an upper link mount, and how I would secure that to the axle as well. Originally I thought I'd bolt a mount to the top or bottom of the axle, but I wanted to keep it really clean looking. So I went back and milled the center keyway into both axle halves. Then I machined the 4 link mount to match the keyway. When it's all assembled, the mount is totally captured in all directions and it's solid as can be, even though the screws do not pass through it. The whole assembly is 'lightly' press fit together and very strong. Hope this gives you some ideas! If you have any questions, let me know!
Nathan |
I like it Nathan
Hey thanks Steve. You know, I was thinking this idea would work just as well with a Tamiya steer axle too. They are pretty similar to the Wedico steer axle. No reason why it couldn't be done also!
Nathan |
![]() Quote:
![]() Thanks for the inside look at this. Should be a bombproof design. P.S. Your photo skills are just as impressive as your building skills. It really makes it a pleasure to watch your updates.
#26
Nathan , the tamiya axle does not have the center drop like the wedico thats why I did what I did on my Paystar . It came out alright just need better links .
#27
i just cant beleive the skill in this hobby. its a fun build to watch, plus great pictures and explanations.
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#28
Nathan wonderful job the way you sandwich that together. I had to take a second look look because I was looking for a plate but after taking a second look I see were you have one side of the axle milled so it's is the top for the other side good thinking. Ed
#29
Just found this build. WOW!! Your attention to detail is amazing! What do you have planned for it next?
#30
![]() Quote:
![]() Quote:
Nathan |
#31
yea I got the hole link assm from traxxas . as for machining my own ,thou shalt not jest
#32
A very detailed chassis! Really enjoy your workmanship, but especially the innovative ways to address problems or changes you want to make. Looking forward to seeing more!
Ken |
#33
WOW Nate this is going to be a great looking truck it is as close to perfect as you can get with the details.. I am not a wedico guy but man what a nice rig.
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#34
wow that's really nice got any idea what your going to do for paint you seam to have every thing els figger out.
#35
Very impressive.
Thanks! Rick |
#36
Thanks Rick!
![]() Quote:
Thanks Ken! More updates coming soon!
Nathan |
#37
Okay fellas, I have been working slowly on putting together a new drivetrain for the Peterbilt. I have no problem with the Wedico 3 speed, but space is tight on this model, and I'd like to have more room for other features. Thanks go out to my friend Rick, who introduced me to the compact and tough as nails Banebots planetary gearboxes. He was one of the first guys to use one on a truck and it looked perfect for my intentions! I'm giving up a 3 speed transmission for a single speed that is stronger and smaller, which is a big help. I really want to keep the interior of the cab, and the Banebots gearbox, with a standard 540 motor will entirely fit beneath the cab floor.
![]() Can't say I've ever heard of anyone tearing up a Wedico 3 speed in a truck application, but they have had some failures in the heavier Wedico 966G Cat. If we take a peak inside, just because I like seeing how things work, we can see some plastic gears and a belt drive reduction. ![]() Other then the plastic gears and the belt, everything else does look pretty beefy, but for now, the trans is being pushed off to the side for this.... ![]() I've got a Novak 55 turn motor, mounted to the Banebots P60 planetary box. It's running a 20:1 reduction and feeds my new transfer case, from RC4WD. I did the math for calculating the gearing and I should end up with the truck being about as fast as it would be in 2nd gear, if I used the 3 speed trans. If I run a little more then 12 volts, I should pick up a little more speed, or I can always swap the motor to a 45 turn. Something I couldn't do with the Wedico trans, as you are stuck running a Buhler motor, wether or not you like it. Can't change the pinion gears either, at least not without some custom machining. ![]() I did have to turn down the output shaft on the planetary box. As it comes, it's about .5" in diameter! Huge. I turned it down to a more common 5mm size and milled a flat on the shaft for the set screw to grab. ![]() Here's a picture of the internals. This is only one stage of reduction. The 20:1 box uses two stages, but this is what it looks like. Just add another stage of planetary gears behind the other, and you'll have it. You can also see the shaft I turned down more clearly. It was huge! The bearings that support it are also monsters. It was intended for robots, so it can take some serious load. ![]() Another picture, showing how it goes together. ![]() Finally, one shot of the RC4WD transfer case I will be using. It's a 1:1 ratio, so it provides no reduction, but it looks really scale, and cool. Intended for scale rock crawlers or trail trucks, but it will be right at home inside the Wedico. I just need to machine up some mounting brackets for both the transfer case and the planetary gearbox, and I'll be all set.
Nathan |
#38
Wow love the eye candy them killers are works of art.. Very nice build Nate..
#39
Once again Nathan, i'm humbled by your work. How can I possibly step away from this hobby, when I have someone like you to keep my sights set on?
Killer looking combination you put together.
#40
Thank Paul. Yes, the Killer Transfer case is a beaut. I can't wait to get mounted between the frame rails.
![]() Rick, I'm glad you decided to keep your Wedico. ![]() ![]()
Nathan |
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
