Old 03-24-2013, 01:23 PM
Default Re: Hitachi Zaxis 210
You will enjoy having the ripper, only down side, they don't stay on very long.
Then it's time to put the bucket back on. I seldomly leave mine on the mini excavator
More than 5-10 minutes.
Cheers, Neil.
Old 03-24-2013, 02:32 PM
How long does it take to make a change with that mechanical quik-tach?
Looking good Emil!
Old 03-24-2013, 07:03 PM
Less than 2 minutes to pull the safety pin and rock the jaw, with the crowbar.
And 1 trip out of the cab for each attachment.
Yes Joe, I know you were asking Emil, lol!
Cheers, Neil.
Old 03-25-2013, 12:54 AM
Looking good Emil!
Thanks for the comments guys!
The change takes only a few seconds I´ll post a video.
Old 03-26-2013, 01:42 PM
As promissed:
http://www.youtube.com/watch?v=-mvSazgK8dw
Old 03-27-2013, 12:27 AM
So that allen screw is push/pulling the pins at the back? Pretty slick! You keep the wrench in the cab?
Thanx for the vid.
Old 03-27-2013, 01:58 PM
Short hours at my regular job today
I bought a new motor for the pump on my way back home. It was also time for (an overdue) oil change.
Old 03-27-2013, 03:40 PM
A little video from this evening: http://www.youtube.com/watch?v=LHX_ZoX-Oq4
Old 03-27-2013, 11:39 PM
Which one is the new one & what are the specs of each motor in the picture?
Old 03-28-2013, 12:36 AM
New motor: http://shop.smallsize.no/product_inf...5773e773fd2447
Old 03-28-2013, 12:43 AM
1100kv, hmmm, that's quite a bit... do you have the epa turned to 50-60% max? Are you running 10cell or 3s?
What were the specs of the other brushless motor & why did you change it out?
Old 03-28-2013, 02:04 AM
The original replacement motor from Leimbach is spinning on 12.000 RPM at full speed. That equals to a 1080kV motor using 3s LiPo (as I am).
I´ve set it up to run on 30% without load, and up to 65% with fully open valves. All four functions are mixed with the pump using the radio (Spectrum DX10t).
The old motor had similar specs, but it had some bad bearings. The new motor is bigger, thus I expect it to have more torque.
I´m looking forward to really try it in the dirt
Old 08-01-2013, 12:51 AM
Putting the ripper to work: http://youtu.be/avvmS-_EBUU
Old 09-08-2013, 07:28 AM
Made myself a new dirt road:
http://youtu.be/DBxSoreWBbA
http://youtu.be/aOjXnv1jLa8
http://youtu.be/4uJQ-K8A2-I
Old 04-11-2015, 04:10 AM
The Hitachi was in the shop for a spring overhaul
New and old oil filter
The mars light have been too hot...
Test & acceptance
Old 04-12-2015, 07:29 AM
Moving a large stone: https://youtu.be/HE2LcnQUAac
Old 04-12-2015, 09:50 AM
First time outside this year https://youtu.be/8ZzuJNDry0s
Old 04-22-2015, 04:32 PM
I've not been fully satisfied with the capacity of the hydraulic system. Leimbach has made an upgrade kit for the Medico excavator that I bought. I'm pleased with the initial testing Old pump was app 380ml/s, while the new one is 600ml/s.
https://youtu.be/9h3oDydNsV0
Old 04-23-2015, 12:46 AM
The only change is the pump? Didn't increase fittings or hose ID too?
Quite a change! almost too quick, but not hard to program curves for valve adjustment & pump speeds.
Old 04-23-2015, 04:09 AM
New fittings on the pump, and new hoses between pump and valves.
