Old 11-24-2010, 12:51 AM
Default Re: Help with a bandsaw
Old 01-17-2011, 07:04 PM
tinkertrucker tinkertrucker is offline
tinkertrucker is on a distinguished road
Hi,
Had the same problem. Found a company "Ellis Mfg / of WI.
They had a blade configuration that fixed my problem.
I work with Aluminum mostly -- 3/4" thickest so far
Good Luck
Tinkertrucker
Old 01-22-2011, 06:12 PM
Bellien Bellien is offline
Bellien is on a distinguished road
Lot's of good advice here on almost exactly the same question:
http://www.chaski.org/homemachinist/...hp?f=4&t=88790
Old 11-11-2011, 09:39 PM
Msmaddie's Avatar
Msmaddie Msmaddie is offline
Little miss fabricator
Msmaddie is on a distinguished road
Im sorry if some has said this already. I bought a 9 inch Ryobi bandsaw last night. The mastercraft I bought had a horrible selection for blades. Anyway I put a 18tpi blade on it. Cuts through aluminum just beautifully. Nice and straight. Was a little rough but a few seconds with the dremel it was smoothed right out.
Hope this helps.
Old 11-15-2011, 07:19 PM
FreddyGearDrive's Avatar
Just a stupid question,but why do you guys use a band saw?
A scroll saw is way better for what we do.
W/a scroll you can make long cuts & also cut out little parts.
The only difference is you can walk away from a band while it cuts,but best hope it cuts where it's spoda.
Just a suggestion,try coating the blade with bee's wax.it'll cut down on the side tracking. Although,you have to coat it every 30 seconds or so.But it makes a HUGE difference in how straight the blade tracks.
Just what I've learned since being in this hobby.
FGD
Old 11-15-2011, 11:58 PM
Are you guy's talking about this type of band saw? http://www.homedepot.com/h_d1/N-5yc1...1&ddkey=Search
later, Neil.
Old 11-16-2011, 06:07 AM
Smokin Joe's Avatar
I use router speed controls on my power tools as needed. They are very well built and consist of a small control box with the controller, 4ft male cord and 4ft female cord.
I buy mine at Harbour Freight. Never had a problem.
Old 11-16-2011, 09:04 AM
siuvinson siuvinson is offline
siuvinson is on a distinguished road
FGD
fgd what blades do you like to use on your scroll saw? And is your saw variable speed, and if so what speed do you use when cutting?
Old 11-25-2011, 12:19 AM
For thick metal I use a course blade(low #of teeth per inch),for thin a fine or high # per inch. & variable speed really helps.
Two things to remember when cutting a metal w/a scroll is never force feed it & don't let the blade get hot.
FGD
Old 12-08-2011, 01:31 PM
Msmaddie's Avatar
That's good to know Freddy. I went with the bandsaw cause the guy that sold me the first bandsaw said I couldn't get metal blades for a scroll saw. I still think a bandsaw works well for certain cuts but its horrible for others. I guess I'm buying a scroll saw after work today. But I think I'm going to get a bigger purse so I can wack the sales guy as well lol.
Old 12-08-2011, 02:18 PM
If you're cutting aluminum you can use regular carbon steel blades (raker flex back). Just watch the Surface Feet Per Minute. I've been using them to cut aluminum extrusions for 30yrs because their way cheaper than the good ones and they both last about the same for wht I'm doing. I run them on a wood cutting Powermatic bandsaw size: 3/4x6tpi Raker Flexback. On my Delta 14'' saws I use a narrower blade: 3/8''x.032 x 10tpi Raker. I get good results with them until the metal work hardens from the Anodized finish but that doesn't pertain to our hobby. You can cut thin steel with a carbon blade just run slower but it won't last very long. But for steel use a Bi-metal blade.I have a Lennox Diemaster on one of my big Powermatic bandsaws. I've had it on there for years! One of the best bandsaw blades I've ever used. I think it is a "Wavey Set" 18TPI I've used it to cut steel up to 2'' thick in past and down to 16ga. Works for brass too. I keep it around 110fpm on steel. Some blades obviously cant be used on a home shop bandsaw but if you can find a saw shop nearby,they can make up the blade you desire any length.
Here is a link to their site. Check out the blade selector too:
http://www.lenoxtools.com/Pages/Cate...egory=Bi-Metal
Old 02-25-2012, 10:44 PM
Terry Terry is offline
Terry is on a distinguished road
I know this post is old, but reading it reminded me of a variable power unit that I use for my router. These are very good and hold up to a Porter Cable 690 router with no problem.
http://woodworker.com/router-speed-c...y&searchmode=2
