Old 08-20-2010, 10:49 AM
Default Re: 2 IH 433 payscrapers (ps433-2 moves)
Thanks for the info-I gave up on the mining truck I wanted to build because I couldn't find the correct size tires.
Old 08-20-2010, 10:54 AM
Tom, Why don't you try to cast some tires from silicone? If you could come up with the right size you probably could sell some to others in the same situation. What dimensions are you looking for?
Old 08-20-2010, 03:05 PM
I grew up with IH construction equipment and really enjoy seeing your scrapers. What truck are you considering?
Ken Sharp
Old 08-20-2010, 06:14 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
I wish someone on this side of the pond would do this.
Old 08-20-2010, 07:57 PM
well Matt , it has been on my mind , but with my current makings the demand has exceded the supply
not only that I got to many builds going
IHSteve
Old 08-20-2010, 09:03 PM
tracksntreadslou's Avatar
I agree the construction tire issue is not very good here ...Wonder if the rock crawler parts supplier that makes the scale rig tires could be talked into making a few different versions ..Im sure the are a few guys on here the know him personaly .
THe scrapers are looking good steve...looks like you have the drive pretty well figured out with tons of power to load ..Are you planning to add a second gear as well?
Old 08-20-2010, 11:51 PM
Tanks LOU I was planing to but with the trannys I got to change a lot . so I'm thinking of gearing it up for the high speed and use the radio to slow it down . got plenty of power and weight
IHSteve
Old 09-04-2010, 09:17 AM
td9clyde td9clyde is offline
Dozer Builder
we need some up date pics i been postin on my pan lol ur turn lol i like seein your progress i think your pans are cool i don't know how you guys build in a small scale i like 1/10 so much more room
Old 09-04-2010, 09:55 AM
Because the trucks are 1/16 and 1/14 approximately. The german construction equipment is built in these scales as well. Then there is all the diecast in 1/16 you can use for static loads/staging/cargo.
Old 09-04-2010, 10:05 AM
Clyde nothing to post yet for some reason there's to many projects on the bench , drill press , lathe and mill and not enough operators
IHSteve
Old 09-11-2010, 08:46 PM
boy the dust got thick enough to pan it off got tired of moving my bigger sprockets around finally put them on and tried the scraper out . worked well
Old 09-12-2010, 12:08 AM
What did you say?
You really need to proof read what you've written before hitting the send button.
Old 09-12-2010, 08:28 AM
What did you say?
Sorry the first time I did that
Old 09-16-2010, 07:49 PM
hope you all can see these : unsure:
got both motors in and started on sheet metal while turning on the lathe
Shaft support and rear cross member
fenders and rear fuel tank ( still have to mill the supports out off it , tonight )
I'll get better pic's when the sun comes out . Finally got a few drops of mother nature
IHSteve
Old 09-16-2010, 08:12 PM
Pics are fine Steve, glad to see you figured out good picture taking. :nice:
Good work on the fenders, the scraper is coming together nicely. I don't see the two speed trannies , not on this one?
Old 09-16-2010, 08:25 PM
no , I ditched the idea for now . I just increased the speed through the gearing and I'll slow it down through the radio ( If I need to ) . The boxes I got just would not work for what I want . so when I start putting #1 together I'll build my own . I'm just eager to get one working then fine tune later .
IHSteve
Old 09-16-2010, 11:16 PM
IHSteve
dang It joe , Now you got me thinking about the 2 speed again . After I wrote that previous post ,I couldn't leave it alone .( I get tiered of redoing ) . for some reason ,all my builds seem to take longer then I expect them to
IHSteve
Old 09-17-2010, 02:28 PM
mog mog is offline
Steve don't feal bad my builds never get done. i have a little too much A D D some times but your doing it right so it will take some time. you will have the power now to fill that bole up good and high.
Old 09-17-2010, 02:56 PM
Snochaser's Avatar
IHSteve- I laughed reading your last comment.....I second guess myself on a lot of stuff, just funny to see someone else doing it...got a kick out of it. It's looking good! I think there is a race going on.....let's see who can get there scraper/pull pan to fill the bowl 1st.
Ben
Old 09-17-2010, 04:25 PM
thanks mog , yea she got the guts but slow as heck traveling thats the purpose of the trans to up the travel speed . I'm thinking making my own so low is direct and hi is 4:1 overdrive
Ben
Ben , I do not know if any one else tried theirs , but I loaded mine half full till I got tied of holding the bowl up by hand.
I'll be running the chain drive till I get the trannies made gona take some time by hand X 4 did some more sheet metal while making wheel blanks post on it later this wknd ( no pretty paint now )
IHSteve
