Another fine digger coming up, Like that weight with the logo in it.
How many times do you have to change setting or can you make it all at once? Dan |
Az , Nate thank you
Dan, thank you , 1 setup as of now all done by 3D milling . I'm going to have to set it on the 2* taper from top to bottom to clean up the logo . A sin plate would be nice right now ![]() ![]()
I let it finish up last night with the lights out then finished it in an hr this morning. this is 4/5th of it so far .
sweet!
Lookin good Steve.
![]() What does it weigh? Would it be too hard on tools to do it from steel? I have nearly 11lbs of counterweight on the 850 and there are times it's not enough. How far back from center is your counterweight? I'll measure mine to compare.
![]() Quote:
![]() :edit: I'm finding it hard to believe only 6 lbs it feels much heavier . It has about the same cubic inch volume as a 20 lb sledge and feels about half .
13" from center pivot?
Mine is 9.5" & the entire length of the house is 16.5".
yes , from the center of pivot . From front of cab to back of counter weight is 17.80" X 10" wide . the counter weight is 5" high what is the diameter of your front idler and sprocket ? Mine are 3" major dia with a 2.6" DP for the sprocket .
Front idler is about 3", maybe a bit more... difficult to see clearly with the tracks on & me standing on my head to look.
![]() ![]() ![]() All done now ![]() ![]() ![]()
Oil tanks for both pretty much done . pics from raw block to finish tank . no pics of the chip pile .
![]() ![]() ![]() ![]() ![]() ![]() thanks for looking
But i wanted to see the chip pile
Hi my name is Aaron.... And i'm a truckaholic! |
![]() Quote:
![]() Quote:
You need your own smelter now Steve!
![]() Quote:
![]() HA HA , Reg , yea I could start casting the daytons , It's just quicker to mill them
Nice work Steve
You are in the big league now, your skills are # 1 These machines will be moving alot on material come spring... greg |
Very impressive.
Just curious, but for those of us who know nothing about machining, where does one buy a giant block of aluminum like that? Last edited by FlyingBeagle; 03-01-2013 at 05:43 AM. Reason: Typo |
thanks Greg they should be ready for the fall time . At least 1
![]() http://www.onlinemetals.com/merchant...999&top_cat=60
Steve what scale is this? If you are 11 or 12 inches from the center pin to the back of the counter weight I believe that is more than I have on my DEERE. Ed
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
