Old 04-21-2013, 05:45 PM
dirthalr's Avatar
dirthalr dirthalr is offline
dirthalr is on a distinguished road
Default Re: My first build
Originally Posted by Bigrigger View Post
Are those headlight bezels the ones from PMD? The build is certainly coming along quickly!
Thanks, yep the bezels are from PMD.
Old 04-22-2013, 08:40 AM
Jimmy were did you get the stainless elbows pre bent I bend mine but if I could buy them it would be easier? When you sleeve your pipes you could use stainless tubing K&S metals has the next size smaller that fits into the 1/2 inch pipe and if you silver solder them together when polished the joint is hardly noticeable. Ed
Old 04-22-2013, 06:45 PM
dirthalr's Avatar
Ed,
I got the elbowsfrom www.microgroup.com they are 90° elbow; male-male. The part # is 90MM-8
I thought about sleeving with another tube, but I want alittle more meat to thread when I mounted to cab. A guy could always tig weld the elbows also.
Old 04-23-2013, 09:38 AM
Hi Jimmy thanks a lot for the info I really appreciate it. This will be a lot easier than bending them my self and trying to get the angle wright. This way I ca put them were I want them when I sleeve them with the next size smaller tube and silver solder them together. I should not even see a seam after polishing them. Ed
