Old 03-21-2013, 10:45 AM
onestepbehind onestepbehind is offline
onestepbehind is on a distinguished road
Default Re: Where can i get ribbed aluminium or steel sheet?
i was reading up on monokote but never used it..... but if ya go on towerhobbies.com and look up chrome monokote it tells a little bit about it and comes six foot long and 26" wide for $18.... ya have to heat it up for the glue to stick so i dont know if that would melt the styrene or not. it is a plastic coating though... but just an idea
Old 03-21-2013, 06:46 PM
kingbob kingbob is offline
I've used monokoate before, but since its intended for planes, it likes to stretch tight to cover wings, so i dont think it would adhere to the dips in the plastic, it would try and stretch over them.
Not a big deal, i have 2 or 3 different options for covering it.
Old 03-21-2013, 06:51 PM
oldboy's Avatar
oldboy oldboy is offline
oldboy is on a distinguished road
Have a look at Walthers Model Trains "O" gauge or "G" gauge for car siding
regards Oldboy
Old 03-25-2013, 01:36 PM
Thenewguy Thenewguy is offline
Thenewguy is on a distinguished road
I don't know if this helps try onlinemetals.com
Old 03-25-2013, 03:38 PM
Hmmm, another idea.
Try the mirror-coating for automobile glass. You may not need the ability to see thru it from the backside, but the reflective aspect to prevent others looking in might be what you could use.
I'm sure you could scavenge a scrap from a tinting shop to test it out, and if it works, buy a bigger section.
WhiteWolf
Old 03-25-2013, 09:32 PM
I just spoke to a local steel place, they can get me a whole sheet for $250 plus a few bucks to cut it. Massive price difference!
Would still end up with way too much material though, enough panels for six 53" trailers! Works out at about $50/pair which is great but buggered if id have a use for the rest
Coating styrene might be the only way.
Old 03-26-2013, 03:43 AM
Picked up a bit of styrene with the corrugated metal pattern on it on the way home. This is the 2mm pattern. They go up to 3.2mm, which i'd prefer i think.
Used some chrome tape on it, little bit of a pain to apply, but doable.
Old 04-08-2013, 01:32 AM
This the one?
Looks about right. The sheets I need are 200x1150mm, but locally I can only get a 2400x1200 for about $300. Which does work out at about $50 for a pair, but stuffed if I'd have a use for the 5 pairs I'd have spare!
