Old 01-23-2012, 08:21 PM
Default Re: How To Custom Drive Shaft
Originally Posted by civic83 View Post
I've done this using styrene tube ( its what I had onhand ) works good, won't take as much torque of corse but works none the less
I have not had any issues with these I have pulled my dump trailer all over loaded and have not had one issue with strength..
Originally Posted by Mjr woodie460 View Post
Great how to but I have one question. How do I go about the carrier bearing.
The hanger bearing you see is a F350 steering block that is bolted to the frame..
elephants14 elephants14 is offline
elephants14 is on a distinguished road
That's a good question, I've found some call it different things?
http://store.hkshobby.com/product_in...oducts_id=6642
, but they've been out for a while.
http://www.rcmodelex.com/www-rcmodel...Save-shaft-5mm
They're expensive for me, because of shipping to the US
I've checked RC4wd, Towerhobbies, and more, I can't find them. I'm looking for some in the states also..
Cody
EDIT:
That's awesome, I've got 2 sitting on my desk infront of me, I read it, and Had a DUH moment...
http://store.hkshobby.com/product_in...401c40e375d926
Only place I could find that has the aluminum version... or plastic for that matter.
Old 01-23-2012, 11:35 PM
Mjr woodie460 Mjr woodie460 is offline
Mjr woodie460 is on a distinguished road
Yeah same here. I found one on another site that was a little different but can not find it now.
Old 06-09-2012, 03:07 AM
Joat Joat is offline
Joat is on a distinguished road
Just an update on people looking for the drive shaft bearing support , I got some from here
http://www.toyscube.com/shop/mier-11...ck-p-7712.html
I got 2 shipped to me for $26, took 11 days, I am not endorsing them, just giving guys some options
Old 06-09-2012, 12:40 PM
I think that is the same one RC4WD is selling as well.
http://store.rc4wd.com/T2-Disruptor-...e-_p_2301.html
But the Toys Cube price is $10 and RC4WD is $59.99. Makes you wander just how much of RC4WD's stuff is someone else's just renamed. I know they sell other manufacturers stuff but it is usually under that manufacturers name not RC4WD.
Old 06-09-2012, 12:59 PM
I seen that, and saw the price, no way on their prices, off the top the rccube one uses m2 hold down bolts, rc4wd one uses m3.I'll get the dimensions later .
Old 06-09-2012, 08:01 PM
The are 2 different blocks but RC 4 WD is out of there minds on the price of there's.
Old 06-09-2012, 08:07 PM
Yep we figured that out but it is funny as to how similar they are.
Russisloud here on the forum makes some and they are made to match his cross members.
http://www.rctruckandconstruction.co...ead.php?t=4381
Old 12-23-2012, 09:18 AM
Originally Posted by sharkey View Post
TC, you just saved quite a few bucks, genius idea man !
Thanks Sharkey... ALL my trucks have these shafts on them.
Old 12-23-2012, 01:00 PM
WOW $16 for a bag of 2 that is cheap my HS has them for $24.99!
Old 12-26-2012, 05:16 PM
Dreamweaver's Avatar
Weaver Of Dreams
There the only way to go Sharkey. Mine work great as well.
Mike "DREAMWEAVER" Johnson
Old 01-24-2017, 11:22 AM
scottyk scottyk is offline
So are you guys drilling a hole thru the steel shaft and using a traxxas pin instead of a set screw? I just cant picture a plastic driveshaft yoke being strong enough to tighten a set screw against the flat on the steel shaft, steel shaft being the pinion bearing or transmission output.
Old 01-24-2017, 12:16 PM
Take a close look at the shafts in the photo they are built based on the info in this thread the universals are traxas steel with a set screw.
Old 01-24-2017, 12:21 PM
Here's another shaft shot
Old 01-24-2017, 12:33 PM
Oh I gotcha you used steel yokes instead of the stock plastic ones. Looks good
Old 01-24-2017, 01:01 PM
Yes you can buy the shafts separate from the yokes. I'll have to look the P/N's up when I get home and post them.
Old 07-22-2017, 11:19 PM
THANKS for an excellent idea to a cheaper alternative!
