Old 11-27-2013, 07:02 AM
titandigs's Avatar
Aussie Fabricator
Default Re: New Transmission required Wedico 740 Dumper
Originally Posted by Espeefan View Post
I'd be curious to see what kind of current this motor is drawing, under load, or when it stalls. That could tell you if it's a case of your battery pack not being able to supply enough current to the motor, when it needs it, or if the motor is simply underpowered for the application. Doing the math, at 41 watts (rated) and running on 12 volts, it should only draw 3 amps, which makes me think the motor is actually a little on the weak side.....
Thanks for the thoughts, I will test some more this weekend and see what the current draw is at stall.
Paul
