Old 03-25-2014, 11:08 AM
rc_farmer's Avatar
Master Builder
Default Re: Another KAT on the prowl
I bought this new swing ring. It is approx. 2 1/4 across from inside to inside. The Slipring from rcwd will not fit insode this ring. You will need a slipring smaller than this one. The pinion gear is large thus taking up the space inside the ring. The ideal slewring would have an external tooth.....for that i am still searching. Also i purchased the slipring that is advertised on the KAT website.....it is not going to work either. The wires are somewhat bigger than human hair. and the turntable is about the size of 6 stacked quarters.
http://img02.taobaocdn.com/bao/uploa....gif_80x80.jpg
http://img02.taobaocdn.com/bao/uploa....jpg_80x80.jpg
Giving up is not an option!!!
Old 03-25-2014, 08:13 PM
The Leimbach is external teeth. Contact this place in Germany to get it. (I doubt you find part/price on his website).
http://www.der-getriebedoktor.de/sho....php?sprache=2
The Gear Doctor - he writes good English.
Old 03-25-2014, 08:48 PM
rc_farmer's Avatar
Master Builder
Much ablidged Joe
Old 03-27-2014, 09:15 AM
JAKEBRAKE's Avatar
JAKEBRAKE JAKEBRAKE is offline
JAKEBRAKE is on a distinguished road
Nice upgrades Rob!! Will you use the RC4WD radio for this machine or just a standard?
Old 03-27-2014, 09:44 PM
rc_farmer's Avatar
Master Builder
I did got the new slewring but the pinion takes up most of the space. That rc4wd slipring is huge. I ordered the one from Germany.
Jake: I'm going to use my Airtronics, it has all the mixing features i want for the pump operation.
Old 03-29-2014, 12:17 PM
carp carp is offline
Hey Rob you rdoing an excellent job on this, im interested to know how strong that new slew bearing from china is? would it be suitable for a bigger machine? are the gear teeth metal or plastic?
cheers
Old 03-29-2014, 07:03 PM
rc_farmer's Avatar
Master Builder
Here are several pics of the new slewringw with and w/o the pinion and slipring.
The new ring teeth are made of metal.
Old 05-22-2014, 11:41 PM
rc_farmer's Avatar
Master Builder
Well, I think i have figured out the slip/slew ring problem that has been plaguing the KAT. The pics will explain.
I cut and shortened the rc4wd slip ring down to a workable height
I bored out the diameter of the slew ring to fit the diameter of the slip ring. This not fits atop the slip ring.
Old 05-23-2014, 07:38 PM
tracksntreadslou's Avatar
Hey rob glad you are getting things worked out with the rotory ..Sometimes it takes a bit to find something to fit ..Question ..your opinion on the tracks ..are they cast aluminum and do they look strong enough ?..they look pretty good from the photos
Old 05-24-2014, 09:56 AM
rc_farmer's Avatar
Master Builder
Hey Lou, yes they are cast alum. and they are pretty beefy. I think they are worth a buying to build other projects. I actually bought extra links too.
Old 05-24-2014, 08:37 PM
woodhog's Avatar
woodhog woodhog is offline
Glad you got it figured out now you can move on forward
Woodhog
Old 04-09-2015, 10:58 PM
rc_farmer's Avatar
Master Builder
Got my new cylinders in for the KAT....
Old 04-09-2015, 11:18 PM
who makes the cylinders? i'm having nothing but trouble with my kat..
it will spend most of this weekend at cabin fever on the lowboy
Old 04-10-2015, 08:59 AM
rc_farmer's Avatar
Master Builder
These are the replacement for the original ones. I got the second version of the KAT and it came with smooth cylinders. Once i figured out the hydraulic, everything else was pretty easy. What are you having issues with....im no expert, but maybe can shed some trial and error experience.
Old 04-10-2015, 09:15 AM
stupid stuff. cylinders leaking the pump is shown as
a brushless but i got a brushed and it screams to make
the cylinders move. you cant do more then one function at a tim
Old 04-10-2015, 05:21 PM
rc_farmer's Avatar
Master Builder
You are absolutely right about the brushed pump....if yours is like mine was, the coupler is off-centered too and it wobbles. It sitting in my junk pile. I bought the brushless the same time i bought the unit. I also junked the valves too. These valves are from tawain. they work great. I drilled the open from 2mm to 4mm for a better flow. What you see in the vid is after the mods to the valve block. i cleaned the threaded area REAL-GOOD and applied TL to the nipple and let set....no leaks there and no leaks .....so far from the heads.
Old 04-15-2015, 10:53 AM
are you using the morpower valve??
Old 04-15-2015, 07:10 PM
rc_farmer's Avatar
Master Builder
Yes i am and Hitec servos
Old 04-20-2015, 12:00 PM
rc_farmer's Avatar
Master Builder
Some more update pics:
Old 04-20-2015, 02:06 PM
Looking real good Rob your getting close to being able to dig dirt hopfully you got all the bugs worked out so you can have some fun time. Ed
