Old 04-10-2014, 01:56 PM
Panther F's Avatar
Lightbulb Re: WTF HAPPENED !!!
I've been always leery of using brake fluid because it can react to softer types of styrene.
I've had better luck with Pine Sol, but watch the time spent in the fluid as it can heat-up and soften the structure of the plastic.
Jeff
Old 04-10-2014, 04:57 PM
Default Re: WTF HAPPENED !!!
Jeff
I too was Leery about using brake fluid. I wanted to know how long was too long so I used the back plate of the sleeper as a test subject. I let it soak fully submerged for 12 hrs. The paint wiped right off and absolutely no effect or damage to the plastic. So even with paint removed I threw it back in for 24hrs. No damage or softness at all. Even the moulded rivets are still strong and sharp.
Then I knew I could strip the cab with brake fluid and not have to worry. As Aaron said, painting worries me and should be left to professionals.
I used DOT 4 type fluid by the way! I have no idea what the effects of using DOT 3 or any other type of brake fluid. I don't want anyone to use the wrong type and then blame me because I said it was ok.
Old 04-10-2014, 08:58 PM
the problem with brake juice is not what happens today, but what happens
weeks,month or years later. I lost a Tamiya bruiser body to the juice
20 year old body started to crumble to a powdery pile
Old 04-11-2014, 01:48 AM
Ive had that happen with the primer.. On a new washed cab... so I don't think its a reaction. its just the B**** of painting and temps etc... IDK I hate paint.
Old 08-24-2014, 09:12 PM
Without knowing exactly what paints used, it's one of the two,-- products weren't compatible or products weren't compatible and too thick of coats. Some useful tips in painting are now a days always use same product. A lot of different chemicals to flash faster/slower, thin/thicken time between coats are used in different companies and the paint may be compatible but the solvents may not. I think that may have been the case along with too thick of a coat. I've always experienced the talent in painting is having the discipline to prep correctly and to spray more coats at a very light covering. Try to do the detail (hard to cover or difficult to get to) first. On these types of things I've switched to all waterborne paints. Can still be used with a 2k clear. And you don't have to be that great at painting or to have a high $ paint gun. Spray cans are fine , just remember to start spraying then hit the part. You just have a harder time applying thin coats with cans. But treat it same, light light coats, read the labels and always make a test sample. The really good guys take the time and have the experience of reading the paint (its flash , thickness, and when to stop!!). The biggest hurdle I had was the discipline to stop when I was ahead not saying "oh there is a little spot that could use some more-then seeing a run cus I put too much on!"
Old 10-11-2014, 11:37 AM
*Sigh*
Seen this all-so-often when using brake fluid... stuff has petroleum by-prods, and they can attack the plastic.
Me, I use 'Easy Off' oven cleaner, in the pump bottle, not the aerosol. That or sommat called 'Mean Green' bio-cleaner, or 'Castrol SuperClean' in the purple pump bottle.... they have never given me a post-use reaction like this.
All three are 'down-the-drain' safe, where officially, brake fluid needs to be disposed of at an approved depot, like tranny fluid, oil, paint, etc.
Just FYI...
WhiteWolf,
finally painting and assembling a few models...
