Old 12-30-2014, 01:58 PM
rc_farmer's Avatar
Master Builder
Default MorePower Hydraulic
I received my morepower hydraulic pump and valves yesterday.
Two nipples broke off, but i was able to drill them out
All out..time to drill and tap for 5mm nipples
I drilled and tapped both sides of the block. It can with only one side tapped.
Be sure and remove the valves before you drill or tap the body, clean out all the metal and then reseat the valves in the same holes as they were removed....set them with lubricate too so as not to scratch the seals...use thread locker on all the nipples
You may need to put some thread locker on these 2.5mm set screws as well
Works really good this setup
Giving up is not an option!!!
