Old 11-09-2018, 07:48 PM
Bo Wallen's Avatar
Exclamation Re: KH Beam Hauler
Next step, Kerst. And a few more to make.
[IMG]IMG_3450 by Bo Wallen, on Flickr[/IMG]
Built the chassie and testdrive went great. Now to hook up the mast, winches and a body.
[IMG]IMG_3451 by Bo Wallen, on Flickr[/IMG]
Frizzen, This is so much fun. Trying to block my calendar for unnecessary work, so i can finish this bugger.
Old 11-09-2018, 08:39 PM
Bo Wallen's Avatar
I forgot I had this picture that show better the semi wheels.
[IMG]IMG_3410 by Bo Wallen, on Flickr[/IMG]
Old 11-10-2018, 12:02 PM
Bo Wallen's Avatar
Lightbulb Re: KH Beam Hauler
Saturday Morning........One More step. The Winch Motor is mounted.
[IMG]IMG_3454 by Bo Wallen, on Flickr[/IMG]
Now make the Winch Drum.
Old 11-10-2018, 03:45 PM
Bo Wallen's Avatar
So the electronic control box on the lathe exploded.........So winch drum has to wait a bit. Onward with the next step.
[IMG]IMG_3470 by Bo Wallen, on Flickr[/IMG]
Mast section fixpoint. and a cab testing mockup also. looks little small, Or?
[IMG]IMG_3475 2 by Bo Wallen, on Flickr[/IMG]
The steering assembly is there, still, need a bit tweaking.
[IMG]IMG_3455 2 by Bo Wallen, on Flickr[/IMG]
Old 11-11-2018, 07:36 AM
kerst's Avatar
kerst kerst is offline
Default Re: KH Beam Hauler
Looks good!
Kerst
Old 11-11-2018, 08:23 AM
Wombii's Avatar
Wombii Wombii is offline
A huge terminal forklift looks like so much fun to play with! Especially one as nice as this. I think the cab is about the right size compared to the wheel size, but on those I've seen the cab is mounted a bit further back, behind the front wheels instead of over them. That difference might give the illusion of a longer wheelbase and smaller cab, maybe?
Old 11-11-2018, 09:30 AM
Bo Wallen's Avatar
You're spot on Wombii. I'll do a few more fitting today, to see where it goes. Thanks for your input, much appreciated.
Old 11-11-2018, 11:22 AM
Bo Wallen's Avatar
I had to make a static load test, 6 kilos 2 inch in front of drive axle center. that gives zero kilos on the steer axle, with no counterweight on the rear part.
[IMG]IMG_3478 by Bo Wallen, on Flickr[/IMG]
And placed the cab further back looks like a splendid idea Wombii. Sometimes you get lost in your own thinking......... I pulled my brain together this morning and went for it.
[IMG]IMG_3481 by Bo Wallen, on Flickr[/IMG]
By the way, I wanna lift 12.66 Kilos when all is done........should be 35 metric ton.
Oh! well carry on with next step.......
Old 11-11-2018, 11:50 AM
Bo Wallen's Avatar
Just to get the feel for 10 degrees back tilt on the lift mast. And a hood.
[IMG]IMG_3482 by Bo Wallen, on Flickr[/IMG]
Counterweight in da rear will be cast in lead. Mold is in production right **** now.
Old 11-11-2018, 12:11 PM
Bo Wallen's Avatar
Neet to order some rams from CTI.
[IMG]IMG_3483 by Bo Wallen, on Flickr[/IMG]
Test day how strong and size them up.
Old 11-11-2018, 11:17 AM
Pretty cool stuff you got going on sir bo!!! Before long I shall see it in person!!
Old 11-11-2018, 06:22 PM
Wombii's Avatar
Looks great! I would be happy with that.
Old 11-11-2018, 10:11 PM
That's a heck of an upgrade!
The cab might be a little small, hard to tell without a truck or a figure around. It might like the bottom of the door lowered a bit more
I can't wait to see what this turns into!
Old 11-12-2018, 05:42 PM
Bo Wallen's Avatar
Thank you Wombii. It's the most fun build in a long time. Today is Finetuning and put all components in. Steering and Gear shift work flawlessly.
[IMG]IMG_3492 by Bo Wallen, on Flickr[/IMG]
Thanks for your input Frizzen. Yes, the cab is little small, not sure if I'm changing or not. Went to Tractor Supply today, And this Mack fell in my arms.......Had to save it from some kid...... That cab on the crane part is looking quite OK, Just to narrow for Forky. But the shape from the side, I like
[IMG]IMG_3491 by Bo Wallen, on Flickr[/IMG]
Old 11-12-2018, 06:28 PM
Bo Wallen's Avatar
Pivot action shot.
[IMG]IMG_3495 by Bo Wallen, on Flickr[/IMG]
Not too bad, and zero bump steer.
Old 11-12-2018, 06:45 PM
I like the ford tractor cab, it reminds me of a control tower, some aircraft tugs, and a few fire engines from the 70s. But I was trying to scale it off a big Hyster at work, i've never been around the container handlers. I definately wasn't criticizing, it looks cool.
Nice score on the crane, i didn't know TSC had those back in yet
Old 11-12-2018, 07:45 PM
Bo Wallen's Avatar
Thumbs up Re: KH Beam Hauler
It's OK I like when someone put in an effort to make things better or smarter.
The size of the cab is bugging me a bit. but this one needs that Ford Cab i think.
Next one is a different story. The Crane has broken down already I'm a curious guy, I'm thinking I'll put tracks under the crane, and use the Mack cab for a service truck. But that's down the road. Forky first.
Old 11-13-2018, 05:56 PM
Bo Wallen's Avatar
The steering is now done. Works perfectly.
[IMG]IMG_3497 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3498 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3499 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3500 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3501 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3502 by Bo Wallen, on Flickr[/IMG]
And now a dive into Battery holders and a few other under the shell kind of thing.
Old 11-15-2018, 12:43 PM
Bo Wallen's Avatar
Got my electronic box for the lathe back today. So now I can make winch drum and other round things I need.
[IMG]IMG_3503 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3505 by Bo Wallen, on Flickr[/IMG]
The day after humpday is always good.
Old 11-15-2018, 09:35 PM
Bo Wallen's Avatar
Mor of the same pill.
[IMG]IMG_3506 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3507 by Bo Wallen, on Flickr[/IMG]
