gettin better and better each day
That scissor neck is coming out sweet. I like it! Good job
![]() ![]() ![]() Getting towards the end ![]() ![]() ![]()
Both the trailer and napoleon are lookin good . What is the height of your I beams in the trailer deck ? Mike
Thanks for the complements guys, like I've said my welding skills are quite a bit rough but almost all will be hidden
![]() Mikem, the I beams are almost one inch tall. I did not look into actual dimensions of trailers, just went with what I thought. The panoramic pic has distorted it quite a bit. Tomorrow I will try and get a better one. I know I'm about to run into a problem with the actuators, the top (black plastic housing) is just a bit taller than what the decking will be. One of those things of my redneck engineering, measure after you build it,,, then engineer some more ![]()
That's awsome that's all I have to say!!
Put a live roll on the back of trk frame & a winch behind trk cab, then the scissor neck will function like a real one.
![]() Quote:
This is what I'm aiming for joe ![]() ![]()
http://youtu.be/WRoj1bkmcxc
And another video I found. Now how cool will that be? Stay sitting in my lounge chair and not have to unhook anything!!! That's why I was going to make this have its own radio system. Just have to install a fifth wheel unlock servo in the truck and I'll only need to get up to pee or refill beverage. ![]()
http://youtu.be/6FWF0a1Rt7w
Finally got it figured out somewhat!!! Still need to limit the lifting legs so the neck will elevate completely. But it is self contained rc!!
Putting a floor on the main deck, would that work for leg stops?
Looking good. ![]() Turn your Iphone a 1/4 turn when filming. ![]()
![]() Quote:
![]() Yes putting 1/8" thick bass wood on for decking. But I am going to place a metal stop in frame rails to facilitate the landing legs to stop and allow neck to raise higher. I still don't know if two actuators will be enough power to lift when 60# plus load on. If not I can add one in middle or two. Haides or high water I'm bound to make this work!!!! Also have to figure out the movable kingpin. That might just be gravity to facilitate that or simple spring band. Figured you guys have remote quick change buckets for the excavators, so when I'm not around the easily motivated kids to unhook something I can still enjoy my lounge chair ![]() ![]() ![]() ![]() ![]()
![]() Quote:
![]() The king pin was in a tube and was gravity activated. It was a 4" pin (read heavy) vs. a standard 2" pin. I would think you could do the same, maybe add a lite spring to make sure it drops when it needs to. ![]() |
Cooper why don't you use alder as opposed to basswood it is harder nice grain and would take a 60 # load better load . If you want some email me off list with a list . Mike
![]() Quote:
![]() Quote:
As far as you are I wouldn't go the winch way, you pretty much got the "lazy" down pat just deck it and tune it to the weight and your good!
I'll keep you in mind mikem, thank you.
Truckmaker, I got to messing with it tonight. Put some temporary stops on the outriggers/landing legs. Lifts the vice I had on it along with four 123 mill blocks. But,,, I don't think the actuators will be able to completely lift the heavy excavator. I think another one in center is needed, maybe two. I'm very close on clearances to put two on each side, side by side. I don't think I could use e-clips on the shafts, would have to change to a set screw to give me a bit more wiggle room. Center has more than enough for one or two side by side, but then more drilling and welding in a rather hard to get to area. It's always gonna be I thought I had enough on the shelf at home but,,, but I need to get more parts !!! But good news is I have the clearances just right for the truck hooking up with fifth wheel. And definitely have to cut some spring steel to add to leaf springs on truck. Squats stock right away. It's one of these circumstances, have truck,,,,, build trailer,,, need to modify truck to suit built trailer. It may just get completely out of hand if a king hauler is needed, extra drive axle, different tranny/motor,,,,,,,,,,, help me I've got to stop!!!!!! Lol!!!! Really need warm weather to get here fast, it will get me outside!! ![]()
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
