Old 09-03-2010, 10:26 PM
Ah, that was a huge mistake! I originally was going to make collector rings like the real machine only 14 circuits. I bought a $45 piece of Static dissipating UHMW plastic to machine out then press copper rings in each. After I spent a whole day machining them I was reading that the material was a good insulator only to find that was a typo in the McMaster Carr book. Static Dissipating CONDUCTS electricity! The salesman said I could send the mtl back but I told him I already cut it up. So I scrapped the idea and started buying rotary slip rings that came up on Ebay and I bought several to try. Now I know how much current the machine uses I may be able to put a slip ring in with more conductors. I have one the same size and make but 24 wires. With this type I could hard wire the whole machine and forget about using a radio to control it.
Old 09-04-2010, 09:30 AM
mog mog is offline
looks good mabey i can get you some pic of a P&H 9020 it's going down hear on tusday and they are going to be lifting the tub off the center pin BIG JOB hope to get out of the shop and see how they lift it. i saw some mammoet trucks in town not shere if they will be doing the lift.
Old 09-04-2010, 01:20 PM
Thanks steve-I really like that slip ring you used. The one I used in my shovel had such small wires I really struggled with it. Also I needed more wires.
Old 09-05-2010, 10:45 PM
dirtpusher9's Avatar
Moderator
Hey Steve, you being a fine machinist, it sure would be cool if you could build the hydraulic pumps we use in this hobby. The kind off work you produce it would be an easy build. And it would keep the money in the good ol USA.
Old 09-07-2010, 12:03 AM
I would have to see one. I could add this to my long list of things people want me to make along with my own projects
Old 09-08-2010, 12:38 PM
Here's some pictures of the load drive and hoist drum parts....
Hogging out a pice of 2x4 steel.
Profile
Walking jaw clutch
One of the bronze two piece bushings on load shaft
milling out the bearing support for the walking pinion
Boring a bearing cap
Ditto
Some parts of the main machinery frame side
Mock up of load drum
Mounting hole for walking shaft bearing block
Just fit on the table
boring hoist motor mount
Cutting Hoist laggin
Hoist assembly parts
assembled hoist
Old 09-08-2010, 12:42 PM
pugs pugs is offline
Very nice work
Jeff
Old 09-08-2010, 04:04 PM
This model is just amazing... The hoist drum/shaft assy looks just like the ones that have come through our repairs shops over the years. Showed the picture to one of our service techs and he was hard-pressed to believe it was a 1/16 model! Just a marvel of machine work.
Old 09-08-2010, 09:11 PM
tracksntreadslou's Avatar
I agee Great work steve..If you need some phots of a Jung Pump torn down let me know ...These pumps are rated for a 120 bar ...think thats whats running Ed machine
Hey Steve I have access to all kinds of coal about 30 minutes away ..Say the word and i will get a couple pickup loads and bury a layer in my back yard .LOL ..would give you a couple years work..after you strip then we can haul it over to "Steamer" robs and he can run it in his locomotives
Old 09-08-2010, 09:27 PM
I don't need to look very far, about 25'below my house the Pittsburgh seam is there that's about 9' thick
Old 09-08-2010, 09:39 PM
Lol...Maybe about 200 years of work for the 9W
Old 09-09-2010, 08:22 PM
Moderator
Wish you could work on this thing all the time, I'm ready to see it finished. It's going to be sweet.
Old 09-10-2010, 09:15 AM
Here are some photos of the walking machinery. I can't seen to find more. I wonder if that roll of film is still in my old camera that quit before I used digital.
Mock up of the upper and lower pices
Rough Milling the kidney shape on the matching half's
Final finish and rounding over the track
Profiling the T shaped pieces that that cam pushes against
More milling and drilling
Cam Milling
Matching the square drive on walking shaft for a perfect press fit
Milling the mount on the shoe
Milling the taper and bull nose on the bottom of walking unit
2 almost completed walking units
Old 09-10-2010, 09:20 AM
Good God you've got a lot of time invested in this, and it shows. Awesome work on the machining.
I've never heard of such a machine until I saw you on Scale4x4 and had to a search to see what it was.
I can't wait to see a vid of yours in action.
In VA? Check out
Old 09-10-2010, 09:25 AM
Here's the link to my videos. There are some crude videos there of it's progression so far.
http://www.youtube.com/user/Scentlessapprentice9
Old 09-10-2010, 03:04 PM
D8R D8R is offline
What CAD program do you use?
I was lucky to get digital readout on my milling machine but how funny to have a CNC.
Guess that out of budget for modelling purpose only.
Very impressing model, do you count hours put into it?
Old 09-10-2010, 04:37 PM
Dan, I have a older version of BobCad V19 and it works ok for some things but can't do all the functions on my control without tweaking things some. I have their newer 2007 (V22?) but I hate it and wasted my money on it. I'm just an old dog who's processor can't take in much more info
As far as hours, who's counting. I'll be going into my 9th year soon. I did keep some track of the milling of the bigger walking parts and it was around 100hrs.
Old 09-14-2010, 09:15 AM
Another flashback that took me about 3 weeks in the evenings to machine out the fairlead from a 3'' x 3'' block of steel turning it 90deg each side.
Old 09-14-2010, 09:45 AM
Always nice to see your work in progress shots. Wish I had the space for a full sized mill and lathe. Guess I will just have to plug along with my Sherlines! Still need to upgrade the CNC version. Looks like next year at the earliest now. Too many home improvements and vehicle repairs for this year.
Old 09-14-2010, 02:31 PM
D8R D8R is offline
Those parts are like arts, guess that with a CNC machine , you still have to put in hour of design of the part in CAD program. Best is that it can be reproduced from files if needed. Have not had any chance yet to test CNC milling but do a lot with laser cut with very good results from CAD drawings.
Hours, weeks or years, who counts but I couldn´t resist to ask, that´s no 1 question when showing the models, my model was started also 8 years ago but there has been some time without anything happening.
Dan
