Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Scale Buildings, Warehouses and Structures.
Scale Buildings, Warehouses and Structures. If you have buildings and other structures that you have built to use with your Rc's here is your place to share them.
Old 01-09-2017, 07:59 PM
Default Wanco vertical mast arrow board
A while back I noticed one thing that i see *everywhere* around construction equipment, but i don't see it anywhere in 1/14 stuff online...
I need an arrow board!
http://www.wanco.com/products/detail...148&type_id=10
Little math and caliper time later, i broke out the solder station.
http://www.555-timer-circuits.com/flashing-led.html
15 yellow 3mm LEDs, a 555 timer chip, 2 resistors, a capacitor, an on/off switch, and 3 position switch. I can turn my board on and off, or set it to point either direction, or as a center line for slow moving hazard.
I have it set as mono flash instead of sequential since that's all i ever see around here, and the circuit is much easier to build. Right now i'm sitting around 4 sec on 4 off, i need to play around with component values to get the flash rate up to 1/2 - 1 hz.
Then i'll need to get brass stock and build the trailer!
Edit
Their site now shows the 15 light boards having 7 modes.
Mine has 2 modes. It can be 3 mode if you use a 3 position center off switch, but it's not the full line.
