Old 04-18-2022, 02:01 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: Build an Excavator from Scratch
Several times before, in some other projects, I've wished to be able to build my own little louvers.
A previous attempt to make a punch and die works but has imperfections to build a even row of identical louvers.
Today i've started another attempt.
the groove for the die was made with a radius mill and cut off one side.
A sharp cutting edge was added.
The die mounted on a piece of wood together with a stop and a ratched grip
with a quadrant milling cutter i've made the punch.
the punch guide
all together clamped an read for the next louver
you can use a hammer or a press.
the result. I'm happy with it and look forward to make some of them for the hull of the excavator.
Regards
Ralf
Old 04-18-2022, 03:39 PM
WOW that took a lot of work but excellent results...
Old 04-18-2022, 06:53 PM
Very nice piece of work there. May just have to copy that. Thanks for sharing.
Old 04-18-2022, 09:25 PM
That louver punch is wild, they look great!
How do you register alignment between the base and punch holder?
Old 04-19-2022, 11:25 AM
I've faced both parts sides together on the mill. Thereby they are absolutely even and a optical alignment was exact enough.
Regards
Ralf
Old 04-28-2022, 03:48 PM
A medium issue I've found was the unwanted contact between the superstructure and the undercarriage regardless all the ball-bearings.
So i've added another dedicated flat bearing from igus. called "iglidur"
A .5mm thick plastic, easily cutable with a sciccor.
Glued direct onto the stainless steel with a combination of loctite 770 and 401.
After deburring and polishing the sprocket a first test
Then the optical improvement of the undercarriage begins
The front inner View is now this
And the side view before
and after the improvement
Regards
Ralf
Old 04-30-2022, 06:02 PM
Second side panel is done.
the first inner rear cover too
a bit bored by all the cutting and bending I need a bit alternation. so i've milled the teeth for the bucket.
Regards
Ralf
Old 05-01-2022, 01:52 PM
Making the working lights. Modern squared style. 15x15x8mm.
each includes 8 smd leds.
.3 mm stainless steel.
Regards
Ralf
Old 05-06-2022, 01:41 PM
the stick need some reinforcements.
copying the shapes
apply to 1mm stainless
saw
sawed
after welding these points
turned into this
with this little tool
stick is finally finished and ready to use
Regards
Ralf
Old 05-07-2022, 09:39 AM
These parts are looking great, and it looks like you'll have a bulletproof model when its done.
Old 05-08-2022, 01:40 PM
bulletroof? i hope so
the bucket links are done in a really quick and dirty way. they work but are very wobbly and a good portion of the hydraulic power goes not in the correct direction.
for a proper working they need more guidance.
Therefor i've turned some brass washers 10x15x1mm
and fitting bolts and screws . ( sorry no pic)
every joint is now backlash free and covered with brass bearings.
Regards
Ralf
Old 05-12-2022, 02:27 PM
finishing the parts was much more work than expected.
improvements, making more finger friendly, welding all the lines complete and not just some points.
and at least put a brushed surface on it.
Regards
Ralf
Old 05-13-2022, 02:37 PM
I was going to ask how you were cutting your parts, then I saw your saw. You've got some fairly tight curves that you appear to be cutting. What are you using for a blade on that saw?
Don
Old 05-13-2022, 04:18 PM
Don
Hi Don,
the saw is a Proxxon MBS 240/E and the blade a proxxon 28 172 for stainless steel.
The shown curves are the limit for this blade. Narrower curves are possible only with little steps side by side.
Regards
Ralf
Old 05-13-2022, 04:52 PM
Blender's Avatar
Blender Blender is offline
This is looking great. The beauty panels pulled it all together so well. The metalwork shows your high standards.
The hard pipes on the boom are a great detail.
Old 05-14-2022, 03:02 PM
thank you.
Next thing to improve is the motor mount of the rotary drive.
first attempt. principally working but too weak for the complete weight of the upper construct.
The motor is strong enough, so i need just a better adjustment technic and a more stable mount.
First part is the combined clamping and movement thing
a plan
and the real thing
more to come....
Regards
Ralf
Old 05-16-2022, 02:02 PM
the wedge bar is done. cutted from a stainless steel bar.
fits well
Regards
Ralf
Old 05-17-2022, 03:14 PM
Still working on the rotary drive.
Today the outer clamps and their flanges to the platform were built.
Befroe that, the old flanges have to remove from the platform. i've used the little 35 mm cuttings discs from proxxon.
The outer clamps get some recesses for the weldable flanges with m4 threads.
After this a first setup of the mechanism happens
works fine but needs some more details before completed....
Regards
Ralf
Old 05-18-2022, 02:10 PM
Last part of the rotary drive.
clamp screws with stainless bolts to avoid damaged threads
adjustment with a simple block on the maximum position and an offset of 1/10 mm with a feeler gauge
clamps very well, no more wobble even if i simulate lateral forces like when the bucket is digging
Regards
Ralf
Old 05-22-2022, 03:30 PM
The work on the cabin begins.
Some angle-guides...
for this little micro belt sander,...
together with a 90
Regards
Ralf
