Old 09-19-2010, 05:44 PM
Texasperry's Avatar
Texasperry Texasperry is offline
Texasperry is on a distinguished road
Default Re: Perry's Leimbach Build
Did some work running hydraulic lines today. I removed the valve block to move it back as Joe suggested. Also to relocate the aux. valve. I was not succesfull in removing the hoses from the valve block without damaging the hoses. I hope I have enough hose to finish the machine. I had to order some drills and taps to complete the valve block move as well.
Joe do you run two battery Packs or a modified battery pack.
Perry
Old 09-23-2010, 12:46 AM
I use two seperate 2700mAh AA packs, laying on their side - stacked up. The batt that runs the pump is always on top b/c I'll change that one 3 or 4 times to the other one that runs the rest of the model electrics.
You can't remove the hoses from the barb fitting, trim the hose with a sharp blade as close to the fitting as possible, if you ever need to remove. Then you'll have to cut the rubber hose that remains on the fitting.
Old 09-23-2010, 12:42 PM
Texasperry's Avatar
Thanks Joe, I discovered that I can not remove the hose. I had to do exactly as you mentioned.
