Old 10-18-2010, 02:52 AM
Default Re: Espeefan's slow motion Peterbilt Heavy Hauler build
Nathan you give new meaning to the word perfectionist.
Old 10-18-2010, 07:51 AM
Thanks for showing the new tranny system. I have one of the transfer cases' in my Studebaker. Only problem I have found with it is its tolerences. Shafts have way too much 'play' in them. Other than that they are very heavy duty like your gear reduction.
Can't wait to see your Pete completed.
Old 10-18-2010, 06:58 PM
tamiya_trucker tamiya_trucker is offline
tamiya_trucker is on a distinguished road
Wow Nathan you still working on this? lol looking good tho, i think both our projects are taking a little to long compared to other one here! That tranny combo looks bullet proof, i really like it.
Old 10-23-2010, 08:55 PM
Originally Posted by SANDCRAFT TRANSPORT View Post
Well I’ll be dammed I can see C510 Kenny road train stamped all over that, & I didn’t even ask for it, Thanks Mate HA HA
Bloody marvellous bit of work you have there Nathan
Tim
Hi Tim. Yes, if you are looking for a rugged transmission for your C510, this would be a great option. There are quite a few different ratios avilable too. I've got a 3:1 reduction in my axles also, so I choose the 2 stage planetary with a 20:1 reduction. It runs really smooth and makes the motor a torque monster! I test ran this combo on 7.2 volts, and I couldn't even make the motor groan, no matter how little throttle I gave it, and no matter how hard I tried to grab the output shaft with my fingers. I don't think you could stall this combo out, in a truck application. On 12 volts plus, it's going to be unstoppable!
Thank you Craig. Just trying to build the best truck I can!
tc1cat, I'm curious if by 'play' you mean shaft run-out. As in not turning true and straight? Or do you mean shaft end play, or float? I don't notice any run-out with the shafts. They look straight and true, but once I get some power going through it, and get the u-joints hooked up, then I'll really know.
Thanks Kyle! Yes, this is turning out to be a life long project, almost! I hope that my work ethic is not rubbing off on you too! You used to crank Aeromax trucks like crazy, till you started the 6x6 boom truck. But, good things are worth the wait, no doubt! If I could only stay off this forum, and avoid looking at what everyone else is building, maybe I'd stand a chance of actually getting some work done on my Wedico! And speaking of that.....
I was able to machine up a new chassis cross member. Since deciding to revamp the drivetrain of my truck, I was in need of way to mount up the new transmission. I also needed a way to mount my cab, after lowering it for the new stance. This is what I came up with.
I designed it to fit perfectly between the chassis frame rails. I still need to drill and tap some holes to secure it to the frame rails, but it's a press fit into place and I haven't yet decided it's finally resting place. I may slide it fore or aft, just as soon as I get some mounts made up for the transfer case next. Driveshaft length will determine the final position, but it will be hidden completely by the cab.
And then the transmission and motor mount to the cross member, like so...
View from the underside...
And one from the side of the chassis. Once the fuel tanks are on, it will be almost impossible to see, except if the truck is upside down.
The transfer case will find it's home just forward of the lift axle.
That's all for now guys. Let me know what you think!
Old 10-23-2010, 09:05 PM
Rogue's Avatar
Rogue Rogue is offline
Rogue is on a distinguished road
Nathan,
You never seize to make me feel absolutely stupid in some of my designs.
Once again, you have raised the bar.
Rick.--- I suffer from Wedicosis
My other truck is a Komatsu
Old 10-23-2010, 09:45 PM
What a very clean and perfect job you do one your parts I am very impressed nice work Nate..
Old 10-23-2010, 09:52 PM
Brian in PA's Avatar
I'd rather be truckin'
Nathan that truck is so pretty it's gonna be a shame to paint it!!
Old 10-23-2010, 10:07 PM
Great truck Nathan I guess I never paid much atention to wedico's but there have been some realy nice ones show up here on the board. Keep up the good work.
Old 10-23-2010, 10:12 PM
Nathan is your new signature a sign of things to come? Don't take this wrong but I already miss the tractors.
Old 10-23-2010, 10:24 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
Just mind blowing Nate....A true masterpeice at its best....Great job....
One Bus Stop Short Of The Short Bus...
Old 10-23-2010, 11:24 PM
heavy_duty's Avatar
heavy_duty heavy_duty is offline
heavy_duty is on a distinguished road
Great job.I am enjoying every step.You are the man.
Ed
Old 10-23-2010, 11:32 PM
Dreamweaver's Avatar
Weaver Of Dreams
WOW.. Great job Nathan.. The one problem I have with seeing artisans like you at work is it makes me feel like my stuff is crap!!!
Fortunately I thrive on that stuff... There is no such word as "Good Enough" in my book..
Again great job. Keep going.. it makes my build better...
-Mike
Mike "DREAMWEAVER" Johnson
Old 10-24-2010, 06:20 PM
Originally Posted by Rogue View Post
Nathan,
Thank you Rick. I appreciate that.
Originally Posted by Tamiya Cowboy View Post
What a very clean and perfect job you do on your parts I am very impressed nice work Nate..
Thanks Paul. Machining up these custom parts is learning process. A couple years ago, I wouldn't have thought I could do it. It's a mind over matter thing. I have still have a lot more parts to make!
Hi Brian, thanks. Believe it or not, painting is my weak point! It will be a chore to paint this rig!
Thanks Travis. Wedico trucks are nice, but kind of expensive, and unfortunately, not without their flaws. For what a guy has to pay to build one, they should assemble themselves and be perfect.
Craig, maybe a sign of things to come. I do want a dump trailer very badly, but I'll always have something for haulin' red tractors around. Less the flames paint.
Thanks John, for the kind words!
Ed
I appreciate that Ed! Thanks.
-Mike
Hi Mike. I used to feel like that too. The great thing about sharing a project for all to see is that we can all learn something new. I'm a bit of a perfectionist too, so I know what you mean about 'good enough' and 'perfect' I always pull a lot of inspiration from all the great builds I see. It's what pushes me to get this truck done.
Old 10-26-2010, 12:33 PM
Hi guys, I've been on a bit of a roll lately, and I whipped up some transfer case mounts for the Wedico! Now I have a nice way to mount up the t-case and I can continue working on the rest of the driveline. There isn't much left to do, but get the driveshaft lengths figured out, and figure out the permanent mounting location of the trans.
Here is a picture of the transfer case and it's new mounts.
I'm still sliding things around in the chassis, but the transfer case is practically guarenteed to be sitting where it is in these pictures. I just need to drill some holes through the frame rails and bolt her up!
Things are starting to come together, and space is getting tight! I still need a way to operate my lift axle and I was thinking of using a servo, but it will take a little creativity to fit one in now, and it will most likely require some more custom machined parts! That's all for now. Thanks for looking.
Old 10-26-2010, 12:50 PM
pugs pugs is offline
Looking good!
Jeff
Old 10-26-2010, 01:02 PM
Nice and neat mounting!
Old 10-26-2010, 01:05 PM
Nathan that is some very nice work. Ed
Old 10-26-2010, 01:22 PM
RAIDERS RAIDERS is offline
very nice work cant wait to see it done!!!
LARRY,the doggy dish dealer
Old 10-26-2010, 02:35 PM
Very nice build. I'm not in to trucks just yet but really enjoyed all of your excellent closeups. This gives me more insight into what I'd be up against if I were to build one of these trucks. Do you have the overall weight yet? Or did I miss that in all the replies?
Old 10-26-2010, 02:38 PM
I like how you whip thing up. Nice work Nathan.
