Old 04-29-2011, 01:34 AM
Default Re: Hydraulic Pump Motor Control Options
Originally Posted by fhhhstix View Post
Thanks for the explanation. Yes I did take offence!
I work for the CAT Rental Store and work on all kinds of hyd systems by a lot of different manufactures JLG, Broderson, LULL, Bell, Trail King, and the list goes on but hay my boss will be glad you explained to me how it works.
Travis, I know you work for a Cat Rental Store. Relax. I'm not out to bust your chops. If that's what you think the purpose of my post was, I apologize. I was just making a point that pump speeds and outputs vary all the time, so why not do it with a model too. Given the choice, I'd throttle back the pump, AND have a heat exchanger, but if you only do one, I'd throttle back or turn off the pump altogether. Reduce the current draw, and save wear on the components. That's just my opinion. Everybody has one. You don't have to accept or like them, nor take offense to them. I'm just saying....
Old 04-29-2011, 02:30 AM
$8 esc shipped from where and will last how long and who warranties it.
Sold at hobbyking; Turnigy 30A (not including shipping). It's quite small, which is good since space is often limited. I think a ESC is a good option in loaders and ATDs, but in an excavator you might as well go for an on/off switch.
My two main reasons for using ESC/ switch are not to have to listen to the awful sound of the hydpump when full flow is not necessary and to avoid unnecessary draw of current.
Many may think there's a delay in the hydraulic functions when using ESC/ switch, but there really is not. You can save a lot of AMPs just learning to operate machines with hydraulic steering by just driving "smart" --> less battery changes = more fun
It would also be cool to change the counterweight on the trackloader to a heatsink with a fan. That would be almost as "the real ting" I guess.
Old 04-29-2011, 02:51 AM
iaindunn iaindunn is offline
iaindunn is on a distinguished road
Originally Posted by tfmacz View Post
I am looking to take some shortcuts to start with. So If you have the .hex binary files would save me some time initially. I use Eagle for pcb design and I make prototype pcb's on a small cnc mill built for the purpose.
I have your schematic diagram, could you post an image of the copper side of the pcb? It will save me some layout time.
I don't currently have mplab installed anywhere.
Looks like I will have to rebuild my development box.
Thanks for all your help.
Ted
No worries Ted.I'll dig ou the hex files and my layout over the weekend and post here.
Iain
Old 04-29-2011, 08:08 PM
Izzy and I talked about it and it would be cool but I felt it was a bit unnecessary for a toy. Right now with my loader set up it will run for 45-60 min on a battery and that is fine with me. As for the esc yes it has a good purpose but I like to keep things simple and it also give newcomers a simpler way to do things till they get to know their equipment and radios.
Old 04-30-2011, 10:13 AM
Juganought Juganought is offline
Juganought is on a distinguished road
When there is not a lot new, I tend to read these posts. You guys have too much talent but I draw the line here....Izzy and I talked about it and it would be cool but I felt it was a bit unnecessary for a toy. Toy!!!! how dare you Travis No toys in my house.. except baby boys stuff.
Dont mess with ma trucks
Old 05-02-2011, 08:00 AM
Iain
Hi Ted could you pm me and I'll send over files. I use express pcb for layput and schematic and not sure how to post thos here.
I
Old 05-03-2011, 03:32 PM
tfmacz tfmacz is offline
tfmacz is on a distinguished road
I
Hi Iain
I think you should be able to attach the files like any other file. Like when you attached the .txt files for the source listings.
I sent you my email address in a PM. The Express PCB files might be useful, My buddy has used that in the past.
Cheers..
Ted
Old 05-03-2011, 04:17 PM
Hi Iain
Cheers..
Ted
Just pm'd you the files
Iain
Old 05-05-2011, 11:58 AM
Iain
Got them. Thanks.
