Old 05-16-2014, 01:13 PM
tracksntreadslou's Avatar
Default Re: MORPOWER pump & valve
Hey Ed did you get a quote on the 6 spool valve ?
I recentley purchased one of their 3 spool and tried to remove one of the fittings ....seems they are pretty fragile as I broke one of the fittins off ..Wasnt alot of force either ..I wont dare to try another..I am thinking they were glued in for extra sealing because the small nipple left behind would not budge and had to be drilled and tapped out
Old 05-16-2014, 04:08 PM
I would put better servos on these I had some finicky 1s . A hiteck 85MG fits
Old 05-16-2014, 04:26 PM
Have you used the valves yet Steve? Opinions????
Old 05-16-2014, 10:08 PM
Yes in my compactor . I slightly modified them a bit . I bored the feed and return out to accept 5mm fittings also helps with the flow . I'm using the Jung pump with them turned down low ( it's more pump then needed but I had it ) the only issue was the servos seemed weak sometimes would not move or move partially . IMO , it's bulky for a small model but fits well with the Jung in the 825C ( just )
Old 06-01-2014, 01:13 PM
michel pet michel pet is offline
michel pet is on a distinguished road
test vid.
https://www.youtube.com/watch?v=Q2Wp...ature=youtu.be
Old 10-05-2016, 11:51 PM
550166681 550166681 is offline
550166681 is on a distinguished road
can send me a hydraulic valve drawings?thank you!
Old 10-05-2016, 11:52 PM
chenkang5501@163.com
