Old 05-22-2013, 12:26 PM
Default Re: My first piece of equipment - Carson Track Loader
Originally Posted by doodlebug View Post
"Git-Er-Done"
Originally Posted by ihbuilder View Post
ahh come on you can't get any werse then me dive into it like Neil said ^^^
Originally Posted by Stefan View Post
Well that´s a competition where I would stand a chance
Stefan
Originally Posted by MoRockN View Post
Congrats Man!!!! now enough with the talk and lets see some build pix
Thanks guys! Well I'm going to slowly work my way into this build. I haven't started on anything yet, other than the stock plastic tracks, but after seeing Mitch's photos of the Permacon metal tracks, I might see if those will be in my track loader's future! They are nice.
Mitch, thanks for sharing those photos of the tracks as well. They get me thinking about an upgrade. The tracks do look a little soft and brittle. Are they cast from sort of pot metal?
Old 05-22-2013, 12:44 PM
So, the question becomes what do you get for all your hard earned money, when you buy the Carson LR634? A pretty nice machine, actually! I've been looking over the parts and checking out the chassis. It's heavy, that's for sure. I removed the big counterweight in the rear of the chassis, just because I found I am going need to do a little touch up welding on my chassis. I don't know if it was just my luck to get one that had a few defective welds, or if they are all like this. Hit and miss? But it's not a very big deal for me to take care of the problem areas. I may even add a few extra beads, just for piece of mind.
The main frame chassis is pretty nice. Looks to be laser cut steel, with tab in slot construction, and some very fine welds to hold it all together. Now for the bad..... On my chassis, there were a few places where the welds were slightly misaligned with the joints, or completely missed altogether. I am pretty pleased with the construction otherwise. It's very solid, heavy, and strong, despite a few missed weld joints.
This joint is the one that bothers me most. I could feel this part of the chassis flexing, when holding it in my hands and lightly twisting the frame where the loader arms will be. You can see the weld is to the right of the joint, missing it completely. I'm guessing the parts were not in the jig properly, so when the torch made a pass, it went right by it. I'll get this welded together properly, and I'll probably hit all the tabs in their slots too. That way I know this thing will never come apart!
This one is not nearly as bad. The majority of the joint is fine. The welder just missed a short section here. For a mass produced model, that is probably welded with an automated system, a few defects are bound to pop up once in a while. It did slip past QC though! Still, I can't complain. It's a much more affordable model, produced for the common folk masses, and it's still awesome.
Old 05-23-2013, 07:45 AM
It's the little things in life that bug the shyt out of you, isn't it?
Old 05-23-2013, 10:38 AM
JDH429's Avatar
JDH429 JDH429 is offline
Nate, thats my kind of model! Heavy duty. Not a biggie, Im sure its just they feel that those small areas wouldnt affect structural stability..But id feel the same way you do.
Jason
Old 05-23-2013, 11:40 AM
Hi Nate, As I have not purchased any construction equipment yet, I am watching your build with a lot of interest. I thought that I had 1 purchased but some how between my bank and Paypal the deal fell thru. I did get my money back though- many sleepless nights!! Your attention to the details will keep me coming back for all of your updates until you finish what looks to be a great machine!
LYNN
Old 05-24-2013, 10:36 AM
Geez!!! 3rd page already & you haven't assembled one piece of the kit yet. BRUTAL!
Sooo, what do suppose the ETA is before this thing sees any dirt?!
Old 05-24-2013, 11:46 AM
At this rate it will be at least 5 pages before it sees any paint let alone sign of assembly I should be the one to talk- 5 years on 1 truck and still not finished
LYNN
Old 05-24-2013, 12:15 PM
Are you sure it'll only be 5 pages? I've been 1-1/2 years on mine, keep changing directions and now paint colors.
Oh yea, Hi Nate, sorry about the high jack, so you loading dirt yet??
Old 05-25-2013, 01:18 AM
Craig, yes!
Jason, yeah, the model would probably be all right as is, except for that one weld that was missed completely. The outer plate that the bucket arm pin slides through is free to pull away from the other side. I suppose the pin would keep it in place too, but it bugs me this way. Otherwise, I'm quite pleased with the construction.
Thanks Lynn! Sorry to hear your deal fell through, but I'm glad you got your money back! I appreciate the kind words.
Originally Posted by thuangs View Post
Hi Nate, trust me yours is much better than mine. In order to get deep penetration on metal, arc welding needs to be extremely hot. All you need to do just sand it out. Midel looks really nice.
Best regards,
Kevin
Thanks for sharing that, Kevin. I guess I got one of the nice models then. I believe Carson had these frames laser welded together. I would say TIG welding would have been better, but by hand, much more time consuming. I think a little surface prep would have been good too. There is a little porosity in the welds too. I think some oil on the metal caused it. Still, minor. I'm just nit picking now.
Not true Joe! I do have both tracks assembled. ETA? Well it's going to be a while. The weather is getting nice. It's hard to stay in the basement, working on models, and I really would like to finish the Kenworth first.
Probably right, Lynn! So you've got a life long project too? I feel a little better now.
1.5 years, Kent? Man, you're fast!
Well, I appreciate all the views guys. It will probably be my usual snail paced build. Especially with summer coming.
Old 05-25-2013, 07:19 AM
Hey Nate , My beard is grey already
Old 05-26-2013, 09:52 PM
jmking jmking is offline
jmking is on a distinguished road
If you need that welded up I could hit those welds with my tig welder. I live 12 miles east of Mosinee on 153. Pm me if your interested.
