#761
Thanks Bo, I knew something was amiss!! Didn't know cubed scale weight. I forget what the actual weight is, I know at some point in past I added some weight to beef her up but forget actual weight. I'll have to dig out a scale and check. I remember telling people at cabin fever 80# , I'll have to harvest a 9 volt from a smoke alarm and stick in scale. Never have any of those weird square batteries when needed!!
#762
#763
Had a little bit of time to do some more work on the blade. Made the push arm attachments to blade. Still have to trim them to correct distance for blade attitude. This time around I am trying to get everything exact from both sides. And will be swapping out radio so I can use the trannis Rx/tx. Then I'll be able to slow down the hydraulics to be more realistic in movements. Always have something to improve on. I think that's why I never really have a finished model, can make the excuse "it's not completely done yet".
#764
Very nice work that should not break. Ed
#765
Thanks Ed, this time around things are being made better, not from necessity but from more welding/milling experience.
![]() ![]() The spacing is for when blade tilts and cylinder shafts don't contact supports. Probably wider than needed but it also ties into cutting edge reinforcement. The lift braces only have to lift not push so I figured it would tie into better.
#766
And thank you Mario for hooking me up with some pics!!! I'm close with the blade except for the dirt blade with rock guard. But backside is going to be close to 1:1. The cat book I have has only a side cut away of blade and part numbers for cutting edges. Thanks!!
#767
![]() ![]() The brass rod is allowing the shafts to pass into. It is acting as my alignment jig. Trying to keep everything square and aligned.
#768
Well first trial fit with hydraulics working, everything was just tacked in place. I didn't take in consideration of the cylinders becoming more vertical as the blade is fully lifted. So, have to move the lift bushing out about .75". Only problem is I don't want to make all new pieces. They were hack sawed and milled to shape. Just lots of work so another piece will be added and an extra set of holes will be there. If I can press the bushings out I may just weld holes shut. Never know
#769
#770
I'm having issues with photobucket on my I pad, once I load a pic it freezes. So posted from phone and now typing on pad!! Anyway,,, I made the push arms .75" longer. Gives more space between tractor and blade. Will allow better placement of stabilizer bar with the proper mounting area. And this time around I was able to remember not to drill too deep for the mounting holes. And was able to remove pivot ball from old ones and place in new ones. (That was good for the first one,, second one had some colorful language added to it). Still have to mill the ends a bit but for fitting and testing its good so far. Have to attach stabilizer bar ( made new one out of steel) make hose mounts for it, and cutting edges for blade, and some little odds n ends.
#771
I'm sure you have your reasons, and I'm probably not the first to notice, the track pads are on backwards. Just an observation.
#772
![]() Quote:
![]() http://www.cat.com/en_US/products/ne.../18332635.html
#773
One thing I did screw up is how the push arm linkage is mounted to blade, on the 1:50 scale model I have the mount is angled like I have it, on the 1:1 machine it is in line with push arm. I didn't catch that till after I made and attached them!! I keep forgetting the scale models aren't accurate but close. The little details sometimes get changed to make a scale model. It's one of those little things but it bugs me to no end!! Lol!!
#774
Wow, it looks odd but I stand corrected...not standing as tall and holding my as high though...lol
#775
#776
Now that's looking just like the real thing
![]() ![]() Can't wait to see you wear it out! ![]() |
#777
Good job cooper,i sent you a pm
#778
![]() Quote:
#779
thats all looks verry nice - iam interested in your CAT Dozer
![]() how much iss it
Everything which is round rolls well, I´m round... ...so kepp on rolling, keep on trucking!!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Greets from Germany Martin |
#780
Pm'ed you papabaer,
![]() Got primer and first coat on. I'm going to 3d print the rock guard for on top. Black and paint blade face yellow. After looking around on the net, there are a lot of variations of blades. Some made by owners, different year models from cat, so having looked through all of them , it really doesn't matter to me as I've always been more for function verses replication of exact model. ![]()
