Old 06-11-2015, 11:24 PM
Jared Jared is offline
Default Re: Dragline Crawler Build
Looks like that undercarriage will fit real nice underneath the house, Jim. On those rollers, you might want to bevel the edges that will run between the lugs on the track. That way the roller won't be able to catch the edge of the lug, ride up on it and throw the track off.
Old 06-12-2015, 08:17 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Jared,
Good idea on the roller profile. I need to make all of them, the one in the photo is a prototype. I will put a nice big angle on the corner of them.
QUESTION: How tight should the rollers and tumblers fit between the dog ears on the pads? Not sure if they should be close or real sloppy narrow?
Jim
Old 06-12-2015, 01:04 PM
Trucker_Jo's Avatar
Very cool! I have always wondered if someone was ever going to build an older track style like this, and it looks like you're knocking it out of the park..
Jarrett
Old 06-12-2015, 01:06 PM
Looking good jim-that is a nice beefy press you made. I agree with jared on the rollers, just a slight chamfer on the edges should help. I say you need some clearance between tumblers, rollers, etc.. This allows for dirt not jamming the parts. 9W may know something about this.
Old 06-12-2015, 06:15 PM
Rvjimd's Avatar
Not too much "visible" progress today but I have actually gotten a bunch done. I wasn't happy with the brass pins linking the pads so I decided to try taping 2-56 holes in the outside tabs and drilled a clearance hole on the inside tabs. The only 2-56 screws I had are shown in the picture. They don't look too bad although a bit big looking I think. I ordered some button head and some plain set screws. I will try those and decide which way to go.
If I had made this decision earlier i think I would have milled the pads such that there was a shoulder in the outside to let the head of the screw sit flush with the outside edge of the pad.
Jim
Old 06-13-2015, 03:41 PM
I sorta have the same issue, but am thinking of taking the easy out and uesing some 5mm bearings instead of making lots of rollers as they will sit nicely in my K1 track.
By the way progerss so far is looking realy good.
cheers andy
Old 06-13-2015, 04:38 PM
Jim-I think everyone would agree on this. Practice is the best tool. Get to know your machine, find out the problem areas and learn how to work around them. You are doing great so far. Keep working and enjoy!!
Old 06-14-2015, 07:00 AM
Rvjimd's Avatar
Thanks guys! I think I am going to start working on a drive tumbler while I wait on my 2-56 hardware to arrive. I figure if the diameter of the tumblers change so will the idler rollers so better wait on them until I know I have a tumbler that fits the pad links.
Jim
Old 06-14-2015, 09:22 PM
Rakthi's Avatar
Rakthi Rakthi is offline
Hi Jim, brilliant how you learn as you go and sort out the problems as they come. Learning a lot just reading about your trial and errors. Many thanks for documenting the process.
Cheers!
Stephan
Old 06-15-2015, 09:53 AM
Rvjimd's Avatar
I am planning to drive the crawler with chain and sprockets like a full scale. I am thinking about ordering some of this .1227" plastic chain but it says 14lbs tensile strength. Is that is way to weak! I don't have a good feel for that in this application.
https://www.servocity.com/html/plast...l#.VX7XXXA8KrU
Is it okay to post a link like this or is that a no-no?
I already have some .25 inch stuff, but I haven't found sprockets small enough yet. I'm gona need about 7/8" for the large sprocket at the tumbler and something smaller at the motor.
Stephan, I get a bit out of the process too. The other day I was about to make some more little tabs that rivet into the pads. I was starting to clamp them into the mill vise and remembered that I had that little fixture block. I went to my thread just to recall the size and shape of the block to make it easier to find in my pile of stuff!
Jim
Old 06-15-2015, 10:08 AM
Jim,
Check this out and see if its what your looking for:
http://www.mcmaster.com/#miniature-roller-chain/=xmuspu
Old 06-15-2015, 10:44 AM
Jim-your thinking is right on with this. The dia. of the tumbler dictates the size of all the other parts. You may have some work to do on the tumblers but I think you are on top of that. Personally, I would go with the metal chain but finding the really small sprockets may be a challenge. Does the 1/4" chain look too big? You might find something smaller in some clock works sites-not sure. Keep the pictures coming.
Old 06-15-2015, 11:04 AM
Rvjimd's Avatar
Truck maker, thanks for the link. I always forget about McM for parts. I just seem to get stuff other places.
Tom, the .25 looks okay. Maybe just a bit big but not too bad. The common 10T sprocket would even look okay next to the tumbler but I might have to search for a smaller one on the motor.
The little pulley I have in the photo is about the size of the smallest sprocket I have found so far.
Jim
Old 06-15-2015, 04:21 PM
Rvjimd's Avatar
Decided to bolt up both sides again so I took a few more shots.
Shaft coming out the wrong side here, but no problem yet...
Jim
Old 06-15-2015, 04:34 PM
Rvjimd's Avatar
Slip ring? Has anyone tried a DIY slip ring? I have repaired one on a in motion servo satellite reciever and I am thinking about trying it. I guess I haven't looked online yet to see how much they are and how it would fit into the UC?
One of the things with my particular install is that there "should be" a 1/4" shaft in the center of the bed that the upper house centers and pivots on. This way it matches the truck frame, in case I want to switch back to the highway truck chassis.
Jim
Old 06-15-2015, 03:39 PM
Jim-if the 10-t sprocket is okay for size then maybe you could use the same on the motor. When you get a little farther along you can turn the assembly and calculate the speed you need and get a motor that speed. If you get a slow motor it should have a lot of power. Just a thought- keep at it!!
Old 06-15-2015, 10:16 PM
Look for some # 25 chain, http://www.amazon.com/Koch-7425100-R.../dp/B004HKITHA Just saw a refence, that scooters use it. http://www.electricscooterparts.com/chain25.html I have a 9 tooth sprocket for a project, can't remember where I bought it 25 years ago. http://www.surpluscenter.com/Power-T...1-2742-9-A.axd
Cheers, Neil.
Old 06-16-2015, 04:38 PM
Rvjimd's Avatar
I got some of my Enco order today and it had some of the 2-56 screws I was waiting on. I think I can shape the ears on the pads and get smooth operation.
Jim
Old 06-16-2015, 08:21 PM
Wiskybilt Wiskybilt is offline
Wiskybilt is on a distinguished road
Those tracks are so cool! I like that old iron
Life: it's all about the ride!
Old 06-17-2015, 10:59 AM
Jim- isn't it nice to see all that work finally shape into something. Looks good, although that 2nd picture with the close up of the tumbler is confusing to me. The pitch looks good except on 1-pad. That I don't understand. I think all you can do is finish the pads and see if it turns. Hope it works for you!!
