Old 02-22-2016, 07:26 PM
Default Re: Driven front axle options?
Originally Posted by SmallHaul View Post
Agree on all accounts and good informative post. That is cool that the rc4wd 3 speed disconnects the front axle in first. Do you think it is as strong as the stock tamiya trans?
I guess a compromise would be a disconnect trans or transfer case and a lockable front axle.
Does anyone have first hand experience with the lockable Lesu front axle? Is it durable and function well?
It is good trans and just to be clear it is only disconected in 2nd 3rd. 1st is the only gear that awd. One thing thouh it is best to open up the trans and take out the shift springs and relye on the servo to hold each gear as the springs are way to stiff. It take alll a high torque servo has to shift it. Unlike a tamiya 3 speed you can shift with your finger you can't do that with the RC4WD 3 speed.
Old 02-22-2016, 10:29 PM
Great info Travis, Thank You.
Old 07-22-2017, 11:33 PM
Thanks folks for much useful information. I as well was debating placing a powered axle on the front of my King Hauler. I bought it used, & plan to hack the sleeper off, & build it into a logging truck. I think the addition of powered steer axle will make it more functional.
