Old 02-02-2018, 09:15 AM
scottyk scottyk is offline
Default Re: Rc4wd 870k wheel loader unboxing and review.
You actually cannot get it in any form other than RTR, I have tried with Tang and no luck. Also you could have bought a Lesu loader which is the same price if not more by the time your done, in kit form, not even painted or anything. but hey if anyone wants to unload their junk loader let me know! I wouldnt mind picking one up
Old 02-02-2018, 10:54 AM
Originally Posted by jack van View Post
i bet alot of those supposed rtr machines had alot of work done by the customer just so they can use it we should do a poll how many orders of machines from rc4wd work perfect right out of the box with no work
Mine worked right out of the box and I got mine same time as you did. I made some slight changes to my radio to fit my preferences and made a video on YouTube on it. Other than the loose muffler tip, I would say it was near perfect out of box for me.
My only "fix" was lowering the pump speed and unscrewing the pressure relief valve to make the hydros smoother running.
Also minimize using the diff lock as it puts a lot of stress on the gears. Frank mentioned that to me as a tip and just passing that along now.
Old 02-02-2018, 07:35 PM
jack van's Avatar
jack van jack van is offline
well so far as i can figure it there are 4 switches and none are working includeing the switch for pump hehe funny thing they sent me 2 videos on the radio set up haha there idea of help was he pressed every button as many times as possible with blury screen and did not say a word about what he was doing lol
Old 02-02-2018, 11:47 PM
Ok it's time for you to make a video and post on YouTube for us to see what is going on. Show in the video step by step what you are doing. Video all the wires and how it's all connected.
Old 02-03-2018, 11:25 AM
lenny lenny is offline
lenny is on a distinguished road
Agreed on the video, remember shipping can be a rough ride. Hate to see the sledge come out. But I've been there before.
Old 02-03-2018, 01:33 PM
jack van's Avatar
so i am happy to announce that i got the machine to runlol just long enough to blow a hydro line i believe it is on left side lol this machine is amazeing and not in good way
Old 02-04-2018, 07:55 PM
Super bowl morning digging with sound.
https://youtu.be/6tJ1S08B7nw
Old 02-04-2018, 08:04 PM
Northern Farmer's Avatar
Thumbs up Re: Rc4wd 870k wheel loader unboxing and review.
New video is sweet Shawn
Old 02-04-2018, 09:03 PM
trucker n's Avatar
What engine sound is that
Old 02-05-2018, 01:50 AM
Man, so what did you have to do to get pump motor rolling? Has the hydro line that is leaking completely off? May just need to tighten it down or take it off and check washer. Gotta make sure all the fittings are snugged down and have a washer.
Old 02-05-2018, 01:54 AM
Yea, sound on that is awesome Shawn. Have you had to adjust the diff lock cable at all?
According to tracking mine just arrive in Hawaii. Phew...glad it got out before New Years.
Old 02-05-2018, 03:30 PM
jack van's Avatar
yes the sound is very nice i have ordered the light set up since i have to do a total tear down on my machine to replace hydro line on left steareing hope the cylinder is ok if not they will have to send a new one of those as well
Old 02-07-2018, 12:12 AM
Thanks!!
Volvo truck. Had to change alot of the parameters on the software.
Thanks!! Congrats! I haven't adjusted. I checked to see if it was working properly and it was so I left it as is.
Glad to hear you got it all sorted out for the most part.
Old 02-07-2018, 02:43 PM
looked through manual and the forum but couldn't fine the size of the fluid tank on the 870K. How much fluid are people putting in on first arrival?
Old 02-07-2018, 03:20 PM
jack van's Avatar
instruction says about half a tank or to bottom of the filler line is where mine is at when not leaking from broken line lol
Old 02-07-2018, 03:35 PM
Ddidn’t notice a fill line. In the full tube?
Old 02-07-2018, 04:34 PM
Rimrock Rimrock is offline
One can count the tube as the fill line, say the bottom - half way up the tube.
If one need to put the machine on the side, don't forget to temporary seal off the air intake hose next to the filler tube) A suitable self tapping screw will do
Soyland Industrier
Old 02-07-2018, 05:15 PM
Right on, thought that was the case. Ended up taking around 40Ml to get to the bottom of the fill tube. Thanks.
Old 02-07-2018, 06:56 PM
Check again once you cycle thru each cylinder.
Old 02-07-2018, 07:32 PM
One thing I did with mine was protect the clear line from the tank. As it enters the body section it was rubbing on somewhat of a rough edge. A little file work and a rubber slip over boot, all good. Next will be bushings for the tilt pins.
