Old 05-29-2020, 11:00 PM
Default Re: HIAB X-HIPRO 1058 loader crane
Beautiful machining, that's coming along great! Touch them with a deburring tool and those cylinder parts are like jewlery.
Any luck on finding the sliding teflon tape, or does it look smooth enough you might not want some?
I did not even saw those burrs before I looked at those macro shots
Yes, I got two different thicknesses of teflon tape.
Old 05-30-2020, 07:19 PM
Not to hijack your thread but where did you find Teflon tape.??? I've tried googling it to no avail..
I follow these threads and Frizzen is right the work you do is incredible.....
Old 05-30-2020, 11:18 PM
If you search Ebay with "PTFE Adhesive Tape" you should find some
Old 05-31-2020, 12:41 PM
Got it thank you .!!! I was looking for Teflon tape and got all kind of weird hits....didn't think about PTFE...We used it in the military years ago to insulate lighthouse tubes(I know old technology ) ...wanted to put it inside my screw drives....
Old 05-31-2020, 08:55 PM
Glad you found a source for some tape, otherwise i was going to have to ask how much you needed and hope shipping to finland wasn't too crazy.
Keep up the killer work!
Old 06-07-2020, 03:18 AM
Here's a picture of how I placed the ptfe tape (those brown pads on the brass angles).
The second picture is just a closeup of the welds.
Old 06-20-2020, 11:01 AM
I have continued welding parts permanently together, there's still lots of seams to weld
Old 06-22-2020, 11:18 AM
Wow, you are doing very well with your Lampert welder. I picked up an Orion welder last year. No time for the models but fixed some of my wife's cheap thin steel lawn ornaments.
Old 06-23-2020, 06:01 PM
Welds are looking perfect
Old 06-25-2020, 09:04 PM
Trucker47's Avatar
Amazing work Hemi!
How will you sequence the hydraulics to extend in the correct order? Will you make a series of sequencing valves?
Old 06-28-2020, 12:14 AM
Originally Posted by Trucker47 View Post
Amazing work Hemi!
I'm trying to go without any sequencing valves, and hope that the order the oil goes to cylinders, will extend them starting from the first/largest extension.
The plumbing is going to be difficult enough already in this way
Old 06-29-2020, 05:49 AM
If it does decide it needs help to sequence the segments correctly, you could probably make it work some little plates with a 'metered orifice' installed at hose connections, or making a 'calibrated crimp' in a hard line.
That's some pretty micro welding. I wish i were that good at full size.
Old 07-04-2020, 06:02 AM
I got rest of the cylinder brackets welded in place
Old 07-05-2020, 02:51 AM
I test fitted the crane to my old Tamiya based dump truck to see how it fits
One thing for sure, it's going to need some serious support legs to keep the truck upright
Old 07-05-2020, 09:25 AM
@Hemi1966 Fit it to that truck just remove the dump body and put a flatbed body on it
Jake
Old 07-05-2020, 09:28 AM
Smile Re: HIAB X-HIPRO 1058 loader crane
Put that on that just remove the dump body and put a flatbed on it
Jake
Old 07-05-2020, 11:06 AM
Work of art, impressive!!
Old 07-05-2020, 09:07 PM
Wombii's Avatar
Wombii Wombii is offline
Work of art indeed. Looking forward to the day we can see a very long video of it working.
Old 07-06-2020, 08:41 AM
Thanks guys
Here's the start of the support legs. (cross section of it)
Old 07-13-2020, 07:21 AM
I've been machining some smaller parts for the extension cylinders. (The squares on the paper are 5x5 mm.)
Tags
hiab, loader crane
