Old 02-09-2012, 08:50 PM
Default Re: 990 cat loader
do these look beefy enough ?
I've been working on these here and there . get a free min or to when the mill not busy
Old 02-09-2012, 10:45 PM
Look's great Steve, Keep it up
Old 02-09-2012, 10:48 PM
So you're going with a motor /trans combo?
What the diff ratio gonna be?
Old 02-09-2012, 11:53 PM
Joe , 3.3 :1 in the axles 2:1 in the drop box powered by 24v 2 speed dewalthammer/drill motor on 12V . I had an 18volt on it in the test vid . For me , I'm using what I have . I think It'll perform very well .
Old 02-10-2012, 12:40 AM
RAIDERS RAIDERS is offline
Lookin good steve...
LARRY,the doggy dish dealer
Old 02-10-2012, 09:01 PM
dirtpusher9's Avatar
Moderator
You the man Steve!! that baby will be stout now. Great work as usual.
Old 02-10-2012, 09:34 PM
thanks guys I'm really pleased the way it's coming out considering I'm using scrapped material for it the axles are cut from stock for wrap around bumpers that was .125 " to short . the counter wieght is cut from a 1" plate we found on a job back in the early 90's left by pipeliners the drill motor is from a drill I thought I could use on job sites for instaling elc. conduit on concrete walls for elc. serv. without lugging the gen. around (big fail) . So instead of it sitting around collecting more dust , why not put it to real use . I still need to make up the spool carrier ( in steel ) that'll have to wait till I get done with alum. so I don't mix chips . I took a hit on 3 out of 4 55 gal drums full of chips because of it .
Old 02-18-2012, 05:06 AM
RCKiwi RCKiwi is offline
What sort of differential are you planning on using in this beaut Steve? I've been spending a lot of time on a design for a very small LSD for my loader build, but am thinking are they actually needed? With the weight these scale loaders end up, do they actually lift a wheel with open diff's? Sorry, just picking your brain here
Cheers
Glenn
Old 02-19-2012, 08:06 PM
" do they actually lift a wheel with open diff's " not sure what you mean here , Glen I'm using the hpi savage steel diffs out of a nitro truck . they seem to handle some abuse . only time will tell .
I took some time this weekend for myself to unwind to figure out what to do to solve a production issue on hubs so I made some more parts for the axles . when running 2'nd op in the mill for the spool carrier on the same jig that I use for hubs , it still f'n off any how it was a long night but I managed to save the carriers with a pressed in brass sleeve . well enough BS I did take some so so pics
rear axle assm.
front and rear axle assm.
carrier and axles
pivot assm. and parts
steel sleeve over alum. for better wear protection
thanks for lookin
Old 02-20-2012, 01:07 AM
steamer's Avatar
steamer steamer is offline
Steve That a stout looking set of axles. How many scoops will this machine take to load the Mack.
Old 02-20-2012, 03:16 AM
Thanks Steve, yep, I'm using savage diff's too I'm trying to contain the conversion in a standard savage diff casing so I can retro fit at a later date.
Very nice looking axles!
Old 02-20-2012, 07:37 AM
prob. 6 heaped ,I know 1 heaped will load my little 10 wheeler and 1.5 brian in PA 's tri-axle
Old 02-20-2012, 02:51 PM
Wow, Steve. The axles are incredible. Beautifully machined scale replicas. I drool everytime I see something like this. CNC is amazing.
Old 02-20-2012, 09:50 PM
Yah, my other Mack got loaded by one out to Geneva Steel/Hecket slag pit, 1 partial scoop was 18 ton's of drain rock! LOL, Now that's a "Horse"
I wonder where that picture is?
Old 02-20-2012, 11:17 PM
thanks Nate , CNC is cool but can cost you in the back pocket quick
yea there a big 1 Neil , I use to get loaded by a 992 with a spade nose in an old coal pit where they were crushing the lime stone over burden . 1 corner of the bucket 12ton for my lil 12' box . was something to see a tire higher then my cab
fixed my wheel jig thought I would never use this
10" face mill that came with the machine heavy as heck so you set it on the table and bring the spindle down to it
Old 02-21-2012, 07:29 AM
B-Train Hauler's Avatar
B-Train Hauler B-Train Hauler is offline
B-Train Hauler is on a distinguished road
Wow! Great job on these axles! As we said before, CNC is a thing, the man behind is another one This loader will be a beast, can't wait to see it works!
Old 03-14-2012, 07:05 PM
thanks B-train
I'm testing pic quality see what you guys think
Old
new
Old 03-14-2012, 08:27 PM
Steve that is coming along nicely sense the last time I saw it. Ed
Old 03-14-2012, 09:08 PM
Stepside's Avatar
Stepside Stepside is offline
wowza! great work!
East Coast Mini Truckers
Old 03-14-2012, 09:22 PM
I guess that program I told you about worked.
