Old 01-03-2012, 11:56 PM
mpe's Avatar
mpe mpe is offline
mpe is on a distinguished road
Default Re: MPE – 24M Motor Grader Build
Rear support bolted to one side of the frame
Old 01-03-2012, 11:57 PM
mpe's Avatar
mpe mpe is offline
Old 01-03-2012, 11:59 PM
mpe's Avatar
mpe mpe is offline
Cylinder bracket added
Old 01-04-2012, 10:01 AM
pugs pugs is offline
Do you work around a 24m? How did you get all this detail figured out? It looks awesome!
Jeff
Old 01-04-2012, 10:27 PM
Wow! This grader is amazing. Still trying to get my head around the size of it. The molded-in tire markings make them look real, rather than just large rounds of rubber. What are the dimensions of the tires?
Waiting to see all the pieces come together as a machine. Keep up the great work!
Old 01-05-2012, 12:27 AM
mpe's Avatar
mpe mpe is offline
Hey Pugs... I had never been around a 24 or even anywhere close to one or any grader for that matter. All the details of my design came from what I found in pictures and videos from the internet. I did a lot of research on this model to get it as close a possible to full scale. I still have a lot left to do.
Old 01-05-2012, 12:48 AM
mpe's Avatar
mpe mpe is offline
Thanks for the Wow! Ken and everyone else that has stopped by to checkout my build.
As for the tires... The diameter is 130.5mm (~5-1/8") x 54mm (~2-1/8") wide. The weight with the aluminum wheel and rubber is 751g (~26.5oz). Once I get the frame together I will give you a scale reference of some sort.
Old 01-05-2012, 12:51 AM
mpe's Avatar
mpe mpe is offline
Front brackets...
Old 01-05-2012, 12:54 AM
mpe's Avatar
mpe mpe is offline
Assemblied...
Old 01-05-2012, 12:55 AM
mpe's Avatar
mpe mpe is offline
Attached to the frame without the center bracket...
Old 01-05-2012, 08:56 AM
Very impressive build you are very talented person I cant wait to see more..
Old 01-05-2012, 12:24 PM
JZA80 JZA80 is offline
JZA80 is on a distinguished road
i'm overwhelming in this site by all the talent people, just amazing.
kenny.
Old 01-05-2012, 12:53 PM
Iron Art's Avatar
Iron Art Iron Art is offline
MPE, If you were to set a model shop truck along side all your parts, ready to make a pick, I'd be fooled into thinking you were assembling a full size grader. This is going to be a great model, hope to see it completed and at one of the West Coast Toy shows in the future. Fred
Old 01-05-2012, 06:22 PM
JensR JensR is offline
Guess I should scrap my grader
Sensational build!
Will you do a diff lock?
Old 01-05-2012, 07:03 PM
How are the two outer plates joined to the center (3/4''plates?) Not the raised area around the flanges. I can't see if you bolted or pinned because the surface was sanded.
Old 01-06-2012, 01:56 AM
mpe's Avatar
mpe mpe is offline
Sensational build!
Thanks JensR. I am not adding a diff lock at this time.
Old 01-06-2012, 02:07 AM
mpe's Avatar
mpe mpe is offline
Ahh great question 9W. They are machined out of one solid chunk of aluminum with some amazing machining.
Well not really from one chunk. Actually the entire assembly has 5 parts and a lot of M2 screws. I had designed these parts so the screws are on the bottom so they would not be visible.
Take a look...
Old 01-06-2012, 02:08 AM
mpe's Avatar
mpe mpe is offline
With center bracket
Old 01-06-2012, 02:10 AM
mpe's Avatar
mpe mpe is offline
next part added
Old 01-06-2012, 02:12 AM
mpe's Avatar
mpe mpe is offline
The complete assembly viewed from the bottom
