Old 09-17-2010, 09:14 PM
chaseracer's Avatar
Default my first semi build (dump)
some of you would have see this thread on scale 4x4, or crawl canada, but thought I would repost it here.
I have always been interested in anything construction and heavy equipment, been around it my whole life and operating heavy equiment is also my career. as big as my passion is for it in the real world. I find most on my time on the internet is spend looking at crawl canada, or scale rc construction equipment. so I have decided to start my first scale construction build. it will be a Tandem Dump truck.
the base for my build will be a Tamiya King hauler.
here is goes
my first semi kit
cut the sleeper off of the cab, to make it a day cab and so the dump box will fit.
now it is on to making the box. I drew up a couple ideas picked one and started cutting styrene and wood to make the box. basic shape with no detail. sorry the pic a bit blury using phone to take pics.
if you noticed the staples they are to hold the two sheet of styrene to the wood spacer between the sheets
this makes my box side thicker and stronger but less weight then using many layers of styrene or metal. and will also alow me to add depth and detail to box sides.
now there are many box makes and type but I like the western style box, with horizontal ribs instead of vertical lines. so here I go cutting and shaping.
cut out sections for depth and add to give angle, shape and detail.
one side taking shape hopefully I can repeat for the other side
let see how is looks with the truck.
pretty happy with it so far with my limited skills.
really excited about building this one. my time is limited in the shop right now so this may take a while so be patient for updated.
thanks for looking
